[Qgis-user] North arrow in QGIS
    Phil Wyatt
    phil at wyatt-family.com
    Wed Feb 13 02:07:34 PST 2019
...and then you also have the users that have templates with built in North arrows who really don’t have to worry too much after initial template design.
I LOVE the fact that I have full control to do it any way I like!
Cheers - Phil
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Benjamin Ducke
Sent: Wednesday, 13 February 2019 7:56 PM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] North arrow in QGIS
On 13/02/2019 09:30, Micha Silver wrote:
> On 2/13/19 9:41 AM, Frank Sokolic wrote:
>> Hi,
>> I think from a user point of view the north arrow is not considered to
>> be an image so having a separate north-arrow item makes good sense. I
>> find the current method of adding a north arrow confusing as it
>> requires the user  to know the following:
>> (a) North arrows are not added by clicking "Add Arrow"
>> (b) North arrows are added by clicking "Add Picture"
>> (c) North arrows are in the "Search Directories" section of the image
>> properties but this section is collapsed by default so the user has to
>> know that they must open this section and then scroll to the north arrows
> I have no problem with the "Add Picture" approach but it would be better
> to have the "Search Directories" displayed by default. It's not at all
> obvious (surely not to a new user) that you have to expand that panel in
> order to find the north arrow images.
Some empirical remarks, from observing users
that understand cartography, but not technical
UI design decisions:
Out of the ~200 people that I have trained on
QGIS, ~100% did have trouble finding a way
to insert a north arrow into a map layout.
About ~75% of them clicked on "Add Arrow",
and some of those were quite satisfied with
the result; so in the future, expect to see many
maps created with QGIS that have ordinary arrows
adorning them, which more or less point
northwards!
There are various reasons why the current
method does not work in practice:
- people do not think of a north arrow
as an ordinary picture; they think of it
(and rightly so) as a cartographic element
with the same rank as a scale bar; after
all, like a scale bar, it has a dynamic
property (its orientation)
- some think of a "north arrow" as an
"arrow" (which leads to: see above)
- "ordinary images" are inserted into a
layout by using the "Add Picture" function;
that leaves people wondering where to find
north arrow pictures, and they wander of
to Google to find some...
So the complete mental chain here is:
north arrow -> picture -> built-in picture
... and that just leaves people totally
stranded (never mind the fact that the UI
element for browsing shipped images is
collapsed by default, so people will just
scroll past it; and that there is a lag
of sometimes several seconds between clicking
on the tiny triangle and getting to see
actual images; so people will scroll past
it again; and that "Search Directories" is
a UI label that most people don't associate
with anything useful...).
In my view, this is a part of the UI that is
conceptually broken in about half a dozen places,
and there should be a dedicated north arrow
tool "Add North Arrow", exactly where it should
be, i.e. right next to "Add Scalebar".
Best,
Benjamin
>> I don't find this very intuitive.
>> Regards, Frank.
>> On 2019/02/13 09:12, Andreas Neumann wrote:
>>> Hi Hugo,
>>> I was initially also puzzled by the fact there is no "north-arrow"
>>> item for the layout. But if you think about it a bit longer, than you
>>> realize, that it is just as efficient adding an image and synchronize
>>> the rotation to one chosen map, than it is to add a north-arrow,
>>> choose an image and synchronize it with a chosen map.
>>> Do you really think, having a separate item for north-arrow is more
>>> efficient? How many clicks do you save by having a separate item?
>>> Greetings,
>>> Andreas
>>> Am 13.02.19 um 06:11 schrieb Hugo Paul:
>>>> Good day
>>>> I was wondering if there is a more efficient method for adding a
>>>> north arrow to a map layout in QGIS than adding an image?
>>>> Something as simple as just clicking somewhere add -> north arrow,
>>>> and then being able to choose various styles.
>>>> Is something like this available?
>>>> Thanks
>>>> Hugo
>>>> *Disclaimer*
>>>> The information contained in this communication from the sender is
>>>> confidential. It is intended solely for use by the recipient and
>>>> others authorized to receive it. If you are not the recipient, you
>>>> are hereby notified that any disclosure, copying, distribution or
>>>> taking action in relation of the contents of this information is
>>>> strictly prohibited and may be unlawful.
>>>> This email has been scanned for viruses and malware, and
>>>> automatically archived by *Mimecast SA (Pty) Ltd*, an innovator in
>>>> Software as a Service (SaaS) for business. *Mimecast Unified Email
>>>> Management ™ (UEM)* offers email continuity, security, archiving and
>>>> compliance with all current legislation. To find out more, contact
>>>> Mimecast <http://www.mimecast.co.za/uem>.
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
Dr. Benjamin Ducke
Deutsches Archäologisches Institut (DAI)
Zentrale Berlin, IT-Referat
* Projekt "Stunde Null" *
