[Qgis-user] Export data to scale
Geyer Thierry geyer at gigapost.com
Fri Feb 15 07:39:52 PST 2019
Hello,
I am Thierry and I’m a French Qgis user.
My main use of Qgis is related to orienteering mapping.
Qgis is connected to a tile server and I’m mostly vectorizing contour lines, roads, constructions to create a ground map before collecting data on the field with my iPad.
The ground map and collected data are processed on a special dedicated software called Ocad.
In Ocad I can import georeferenced ESRI shape files .shp
I was doing this with Qgis2 and the scale was OK by exporting (saving as) the symbology to a determined scale 1:10 000 with a perfect result.
Since Qgis3 this option disappeared and the result gives me a bad scale even if my scale in Ocad is set to 1:10 000.
I’m searching for months now and can’t find anything to solve this.
Does anyone have a clue how to manage this in Qgis3 ?
Last thing maybe important, I’m running Qgis on a Mac.
Thanks for your help.
Thierry
