[Qgis-user] Export data to scale
Mike Flannigan
mikeflan at att.net
Sat Feb 16 16:02:55 PST 2019
I can't help you. I didn't know OCAD could import a
shape file. That is good to know. I see OCAD 8 will
not import a shape file. Presumably OCAD 10 will, and
maybe OCAD 9 will too.
Hope you find an answer.
Mike
On 2/15/2019 2:00 PM, qgis-user-request at lists.osgeo.org wrote:
> Hello,
> I am Thierry and I’m a French Qgis user.
> My main use of Qgis is related to orienteering mapping.
> Qgis is connected to a tile server and I’m mostly vectorizing contour lines, roads, constructions to create a ground map before collecting data on the field with my iPad.
> The ground map and collected data are processed on a special dedicated software called Ocad.
> In Ocad I can import georeferenced ESRI shape files .shp
> I was doing this with Qgis2 and the scale was OK by exporting (saving as) the symbology to a determined scale 1:10 000 with a perfect result.
> Since Qgis3 this option disappeared and the result gives me a bad scale even if my scale in Ocad is set to 1:10 000.
> I’m searching for months now and can’t find anything to solve this.
> Does anyone have a clue how to manage this in Qgis3 ?
> Last thing maybe important, I’m running Qgis on a Mac.
> Thanks for your help.
> Thierry
