[Qgis-user] Export data to scale
    Nyall Dawson
    nyall.dawson at gmail.com
    Tue Feb 19 14:36:06 PST 2019
On Sat, 16 Feb 2019 at 01:40, Geyer Thierry <geyer at gigapost.com> wrote:
> Hello,
> I am Thierry and I’m a French Qgis user.
> My main use of Qgis is related to orienteering mapping.
> Qgis is connected to a tile server and I’m mostly vectorizing contour lines, roads, constructions to create a ground map before collecting data on the field with my iPad.
> The ground map and collected data are processed on a special dedicated software called Ocad.
> In Ocad I can import georeferenced ESRI shape files .shp
> I was doing this with Qgis2 and the scale was OK by exporting (saving as) the symbology to a determined scale 1:10 000 with a perfect result.
Can you elaborate on your workflow? That option is still there in QGIS
3 (unless I'm misinterpreting your question)
Nyall
> Since Qgis3 this option disappeared and the result gives me a bad scale even if my scale in Ocad is set to 1:10 000.
> I’m searching for months now and can’t find anything to solve this.
> Does anyone have a clue how to manage this in Qgis3 ?
> Last thing maybe important, I’m running Qgis on a Mac.
> Thanks for your help.
> Thierry
> Qgis-user mailing list
