[Qgis-user] Tracking QGIS use of password protected QGIS project with geoserver WMS links
Andrea Aime andrea.aime at geo-solutions.it
Tue Feb 19 06:28:22 PST 2019
Hi Rolf,
if GeoServer is receiveing the user information then it should be loggable
on disk via the monitoring
plugin audit mode:
https://docs.geoserver.org/latest/en/user/extensions/monitoring/audit.html
If instead you have an application in the middle managing security, and not
telling GeoServer who's accessing it,
then the security application would be the place where to monitor.
Cheers
Andrea
On Tue, Feb 19, 2019 at 3:15 PM Rolf Bruijn | Ruimteschepper <
rolf.bruijn at ruimteschepper.nl> wrote:
> Hi all,
> A long time QGIS user here, but new to the list. So a brief introduction I
> feel is in order. My name is Rolf Bruijn. I’m from Amsterdam, the
> Netherlands and working for a small geo-information consultancy firm also
> in the Netherlands. I use QGIS on a daily basis mostly for map making and
> data analysis.
> I’m reaching out to the QGIS community because I have a question. Efforts
> to find an answer using typical online search platforms have been fruitless
> so far. My questions boils down to this. Is there some sort of user
> activity logging system or monitoring in QGIS? At work we share proprietary
> data using password protected QGIS projects that connect via geoserver WMS
> links to a secure server. My manager asked me to monitor who’s accessing
> the server using the password protected QGIS project. We hand out
> personalized QGIS certificates to new employees. So I am confident that
> there is a way to track users via the certificates.
> I really hope the QGIS community can shed more light on my problem.
> Many thanks in advance for your responses.
> Cheers
> *Rolf Bruijn*
> *M* 06 3030 0987
> *T* 073 78 20 168
> [image: cid:image002.png at 01D48024.AB5A3220]
> Brink7, 5236 AR  ‘s-Hertogenbosch
> www.ruimteschepper.nl
> Qgis-user mailing list
Regards, Andrea Aime == GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime
@geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054
Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339
8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190219/709e86e0/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190219/709e86e0/attachment.png>
