[Qgis-user] styling mutiple attributes within the same layer
qgis-user at stripfamily.net
Sat Feb 23 06:56:27 PST 2019
On 2/23/2019 7:06 AM, Andreas Neumann wrote:
> Hi Groene,
> you can set multiple styles on a single layer. No problem. Just right
> click the layer, select styles and add a new style.
> Greetings, Andreas
Related tip:
to quickly change between the different styles, use the "Layer Styling"
panel:
View->Panels->Layer Styling.
The left side of the panel (at least in 3.4) contains a column with 5
icons. The 4th one is "Style Manager", which will present a list of the
styles defined for the layer. You can select the style to display by
clicking on it. You can also add and delete styles from this view.
