[Qgis-user] styling mutiple attributes within the same layer
Groene Bij
mail at groenebij.nl
Mon Feb 25 06:36:34 PST 2019
Thank you for both tips, they work great, at least within Qgis.
I'll contact the qgis2web authors to see if an integration of multiple layers is possible in the plugin.
Gr.
Jeroen
-----Oorspronkelijk bericht-----
Van: Qgis-user <qgis-user-bounces at lists.osgeo.org> Namens qgis-user at stripfamily.net
Verzonden: zaterdag 23 februari 2019 15:56
Aan: qgis-user at lists.osgeo.org
Onderwerp: Re: [Qgis-user] styling mutiple attributes within the same layer
On 2/23/2019 7:06 AM, Andreas Neumann wrote:
> Hi Groene,
> you can set multiple styles on a single layer. No problem. Just right
> click the layer, select styles and add a new style.
> Greetings, Andreas
Related tip:
to quickly change between the different styles, use the "Layer Styling"
panel:
View->Panels->Layer Styling.
The left side of the panel (at least in 3.4) contains a column with 5 icons. The 4th one is "Style Manager", which will present a list of the styles defined for the layer. You can select the style to display by clicking on it. You can also add and delete styles from this view.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
