[Qgis-user] geojson file permission settings
Mike Flannigan
mikeflan at att.net
Mon Feb 25 16:47:20 PST 2019
I use qgis2web on a Windows machine. Am I naive to think
that others cannot obtain the underlying data for this map:
http://www.mflan.com/temp/wind/index.html
If that data can be obtained I would like to know the
procedure one would use to obtain it.
I'm thinking my map is not geojson, but I could
be wrong.
Mike
On 2/21/2019 2:00 PM, qgis-user-request at lists.osgeo.org wrote:
> I am using qgis and qgis2web to produce webmaps. Each layer is stored as a
> javascript file containing the geojson data. This contains the geometry and
> the attributions.
> When publicly publishing the webmap I want people to view the map. But I
> also want to protect the map data (geometry and attributions) from being
> copied. It's my time and effort to produce the map (geometry and
> attributions) and I don't mind people viewing it, but I do mind if map data
> is being copied.
> When I set the file permissions to 640, the webmap will not show. If I set
> it to 644, the geojson data file is easily found (the index.html shows you
> where it is stored) and then copied.
> Are there other ways to easily host and publicly show webmaps but keep the
> actual data protected?
