[Qgis-user] geojson file permission settings
Groene Bij
mail at groenebij.nl
Tue Feb 26 13:54:53 PST 2019
It is very easy.
In less than a minute I can produce the .shp and .dbf file of your wind farm data and use them myself.
However, since you haven't set any names for the attributes, and I am not an expert on wind farm data, it is difficult to guess what the values represent.
I figured this out myself, using my own maps, being concerned data might be accessible. That's what triggered me to ask these questions. There may be many ways to avoid this issue, but I am no expert on internet security so I do not know them.
Gr.
Jeroen
-----Oorspronkelijk bericht-----
Van: Mike Flannigan <mikeflan at att.net>
Verzonden: dinsdag 26 februari 2019 01:47
Aan: qgis-user at lists.osgeo.org
CC: mail at groenebij.nl
Onderwerp: Re: [Qgis-user] geojson file permission settings
I use qgis2web on a Windows machine. Am I naive to think that others cannot obtain the underlying data for this map:
http://www.mflan.com/temp/wind/index.html
If that data can be obtained I would like to know the procedure one would use to obtain it.
I'm thinking my map is not geojson, but I could be wrong.
Mike
On 2/21/2019 2:00 PM, qgis-user-request at lists.osgeo.org wrote:
> I am using qgis and qgis2web to produce webmaps. Each layer is stored
> as a javascript file containing the geojson data. This contains the
> geometry and the attributions.
> When publicly publishing the webmap I want people to view the map. But
> I also want to protect the map data (geometry and attributions) from
> being copied. It's my time and effort to produce the map (geometry and
> attributions) and I don't mind people viewing it, but I do mind if map
> data is being copied.
> When I set the file permissions to 640, the webmap will not show. If I
> set it to 644, the geojson data file is easily found (the index.html
> shows you where it is stored) and then copied.
> Are there other ways to easily host and publicly show webmaps but keep
> the actual data protected?
