[Qgis-user] QGIS 3 Interface Customisation
Paul Wittle
P.Wittle at dorsetcc.gov.uk
Thu Jan 3 06:22:39 PST 2019
Brilliant, that does work perfectly!
Of course it wouldn’t if you really did want to restrict access to that functionality but in my case I’m just trying to prevent the users being confused so it works perfectly for me.
Cheers,
Paul
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Andreas Neumann
Sent: 03 January 2019 13:38
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS 3 Interface Customisation
Hi Paul,
Have you tried accessing the Options from the "Locator toolbar" in the bottom left? Just type in "General" or "System" and open it from the Locator toolbar.
Perhaps that would still work if the "Settings" menu is disabled? I haven't tried it though - so not sure if it would work.
Greetings,
Andreas
Am 03.01.19 um 13:21 schrieb Luigi Pirelli:
IMHO a good feature request
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Thu, 3 Jan 2019 at 12:41, Paul Wittle <P.Wittle at dorsetcc.gov.uk<mailto:P.Wittle at dorsetcc.gov.uk>> wrote:
Hello,
I’m trying to create a cut down profile for QGIS 3 to deploy as a viewer for low end users. I don’t want to display the settings menu but I do want to be able to access it via keyboard shortcuts so I setup keyboard shortcuts for “Options” as an example. Unfortunately the keyboard shortcut doesn’t appear to work if the settings menu is set to false using the interface customisation.
Is this behaviour what you would expect and if so, would it be worth a feature request to change it?
As I see it you really have three options:
* Display
* Hide
* Hide and disable
The current versions seems to only have the option to display or disable the options but I’m trying to change the menu not disable functionality.
Best Regards,
Paul Wittle
GIS Developer
Insight, Intelligence & Performance
County Hall
Dorchester
Dorset. DT1 1XJ
Tel: 01305 228473
E mail: p.wittle at dorsetcc.gov.uk<mailto:p.wittle at dorsetcc.gov.uk>
"This e-mail is intended for the named addressee(s) only and may contain information about individuals or other sensitive information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this email in error, kindly disregard the content of the message and notify the sender immediately. Please be aware that all email may be subject to recording and/or monitoring in accordance with relevant legislation."
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190103/447cb783/attachment-0001.html>
