[Qgis-user] QGIS 3 Interface Customisation
    Andreas Neumann
    a.neumann at carto.net
    Thu Jan  3 08:41:18 PST 2019
Hi Paul,
Glad it helped.
The locator toolbar has a lot of hidden gems and it can be extended with
your own plugins, e.g. with local gazeteers, queries of your local data
sources, etc. There are already some locator plugins available in the
QGIS plugin repo.
Greetings,
Andreas
Am 03.01.19 um 15:22 schrieb Paul Wittle:
> Hi,
> Brilliant, that does work perfectly!
> Of course it wouldn’t if you really did want to restrict access to
> that functionality but in my case I’m just trying to prevent the users
> being confused so it works perfectly for me.
> Cheers,
> Paul
> *From:*Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of
> *Andreas Neumann
> *Sent:* 03 January 2019 13:38
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] QGIS 3 Interface Customisation
> Hi Paul,
> Have you tried accessing the Options from the "Locator toolbar" in the
> bottom left? Just type in "General" or "System" and open it from the
> Locator toolbar.
> Perhaps that would still work if the "Settings" menu is disabled? I
> haven't tried it though - so not sure if it would work.
> Greetings,
> Andreas
> Am 03.01.19 um 13:21 schrieb Luigi Pirelli:
>     IMHO a good feature request
>     Luigi Pirelli
>     * LinkedIn: https://www.linkedin.com/in/luigipirelli
>     * Stackexchange:
>     http://gis.stackexchange.com/users/19667/luigi-pirelli
>     * GitHub: https://github.com/luipir
>     * Mastering QGIS 2nd Edition:
>     https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
>     * Hire me: http://goo.gl/BYRQKg
>     On Thu, 3 Jan 2019 at 12:41, Paul Wittle <P.Wittle at dorsetcc.gov.uk
>     <mailto:P.Wittle at dorsetcc.gov.uk>> wrote:
>         Hello,
>         I’m trying to create a cut down profile for QGIS 3 to deploy
>         as a viewer for low end users. I don’t want to display the
>         settings menu but I do want to be able to access it via
>         keyboard shortcuts so I setup keyboard shortcuts for “Options”
>         as an example. Unfortunately the keyboard shortcut doesn’t
>         appear to work if the settings menu is set to false using the
>         interface customisation.
>         Is this behaviour what you would expect and if so, would it be
>         worth a feature request to change it?
>         As I see it you really have three options:
>           * Display
>           * Hide
>           * Hide and disable
>         The current versions seems to only have the option to display
>         or disable the options but I’m trying to change the menu not
>         disable functionality.
>         Best Regards,
>         Paul Wittle
>         GIS Developer
>         Insight, Intelligence & Performance
>         County Hall
>         Dorchester
>         Dorset. DT1 1XJ
>         Tel: 01305 228473
>         E mail: p.wittle at dorsetcc.gov.uk
>         <mailto:p.wittle at dorsetcc.gov.uk>
>         "This e-mail is intended for the named addressee(s) only and
>         may contain information about individuals or other sensitive
>         information and should be handled accordingly. Unless you are
>         the named addressee (or authorised to receive it for the
>         addressee) you may not copy or use it, or disclose it to
>         anyone else. If you have received this email in error, kindly
>         disregard the content of the message and notify the sender
>         immediately. Please be aware that all email may be subject to
>         recording and/or monitoring in accordance with relevant
>         legislation."
>         _______________________________________________
>         Qgis-user mailing list
>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>         <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>         Unsubscribe:
>     List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> "This e-mail is intended for the named addressee(s) only and may
> contain information about individuals or other sensitive information
> and should be handled accordingly. Unless you are the named addressee
> (or authorised to receive it for the addressee) you may not copy or
> use it, or disclose it to anyone else. If you have received this email
> in error, kindly disregard the content of the message and notify the
> sender immediately. Please be aware that all email may be subject to
> recording and/or monitoring in accordance with relevant legislation."
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190103/02ae37b6/attachment.html>
