[Qgis-user] Creating PDF bookmarks in Atlas created by print composer?
magerlin
MAP at ramboll.dk
Fri Jan 4 06:42:13 PST 2019
I am about to produce an Atlas in QGIS with 130 maps each showing one road.
It is created as an atlas in print composer and I have a label field in the
layout which includes the road name (from the coverage layer). I use single
file export to get one pdf document of 130 pages, all with identical layout.
I would love to make this document having PDF bookmarks leading to all the
road names for easy reference from the pdf bookmarks panel.
I can use html coding in the label but have still not found a solution on
how to get the bookmarks.
I have found one workaround in creating each map as a single pdf with the
name of the road. Then by merging all 130 pdf to one in PDFsam
(https://pdfsam.org/download-pdfsam-basic/) I can get bookmarks from the
filenames
Any ideas on how to do it directly from QGIS?
Regards Morten
Currently using Qgis 2.18.23 (OSGeo4) and Qgis 3.4.2 in parallel
Windows 7, 64bit
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
