[Qgis-user] QGIS 2.18 -Changing layer rule-based style transparency
Tudorache, Marian
Marian.Tudorache at navcanada.ca
Fri Jan 4 13:32:57 PST 2019
I have a polygon type vector layer with rule-based style.
I need to change programmatically the layer transparency.
I used the following code:
layer = iface.activeLayer()
layer.setTransparency(80)
layer.triggerRepaint()
This works only if I want to see layers which are under the active one but it does not work for the features inside active layer.
When there are identical polygons which overlap within active layer, I can only see the top one. If I select a polygon which is underneath it is not displayed as selected.
I can make it work if I manually open the layer style and double click on rule to open Rule properties and set the transparency for the rule.
How can I change the rule transparency programmatically?
Thank you,
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190104/c9380bc1/attachment.html>
