[Qgis-user] training manual QGIS 3
DelazJ
delazj at gmail.com
Sat Jan 5 02:33:44 PST 2019
Hi Janneke,
Thanks for your tests. And indeed the training manual update is a work in
progress and maybe could you publish your remarks as issue reports in the
doc repository [0] so that we took them into consideration as we go.
You are right about the missing data, there was a pull request [1] to
integrate these data we forgot to merge. Done now! Download the dataset
again, please.
Note that we are reviewing initial lessons and have some pending updates
for both lessons [2] and corresponding data [3]. Tests and feedbacks are
more than welcome. Thanks!
[0] https://github.com/qgis/QGIS-Documentations/issues
[1] https://github.com/qgis/QGIS-Training-Data/pull/15
[2]
https://github.com/qgis/QGIS-Documentation/pulls?q=is%3Apr+is%3Aopen+label%3A%22Training+Manual%22
[3] https://github.com/qgis/QGIS-Training-Data/pull/17
Regards,
Harrissou
Le jeu. 3 janv. 2019 à 13:22, Janneke van Dijk <janneke.qgis at gmail.com> a
écrit :
> Dear all,
> I'm currently going through the QGIS 3 training manual
> (https://docs.qgis.org/testing/en/docs/training_manual/) using QGIS
> 3.4.3 and documenting any changes that would still need attention. I
> understand that it's a work in progress and hope/plan to contribute a
> bit in a later stage. What is complicating matters is that the data that
> I downloaded (QGIS-Training-Data-2.0.zip) does not contain all the
> layers that are mentioned (so far schools, restaurants, network_analysis
> folder and possibly some more that I may have skipped). Is there a
> complete/up-to-date data set available? Where can I find it?
> Thanks for any suggestions,
> Janneke
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190105/b155e22a/attachment.html>
