[Qgis-user] QGIS 2.18 -Changing layer rule-based style transparency
Raymond Nijssen
r.nijssen at terglobo.nl
Sat Jan 5 08:04:14 PST 2019
Already got it working, using the setLegendSymbolItem() on the renderer:
layer = iface.activeLayer()
renderer = layer.renderer()
symbolItems = renderer.legendSymbolItems()
for symbolItem in symbolItems:
print(symbolItem)
symbol = symbolItem.symbol()
color = symbol.color()
color.setAlpha(255 * 0.8)
symbol.setColor(color)
renderer.setLegendSymbolItem(symbolItem.ruleKey(), symbol)
layer.triggerRepaint()
No clue if it will run in 2.18, expecting not. Hoping you can upgrade.
Raymond
On 05-01-19 13:22, Raymond Nijssen wrote:
> Hi Marian,
> As I understand you want to set every symbol in your rule based
> classification to 80% transparent (instead of the entire layer)?
> I tried to write a qgis (v3.4) script but unfortunately it crashes my
> qgis. So I hope somebody here can correct it, or maybe you will find the
> solution yourself.
> I'm doing many prints to see the return values. The crash happens when
> in line 18: symbolItem.setSymbol(symbol)
> print(symbolItems)
> print('---')
> print(symbolItem)
> print(symbol)
> print(color.name(1))
> color.setAlpha(255*0.8)
> symbolItem.setSymbol(symbol) # !!! this makes qgis crash
> When crashing, qgis outputs:
> QGIS died on signal 11Could not attach to process. If your uid matches
> the uid of the target
> process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
> again as the root user. For more details, see /etc/sysctl.d/10-ptrace.conf
> ptrace: Operation not permitted.
> No thread selected
> No stack.
> gdb returned 0
> Aborted (core dumped)
> Kind regards,
> Raymond
> On 04-01-19 22:32, Tudorache, Marian wrote:
>> Hi,
>> I have a polygon type vector layer with rule-based style.
>> I need to change programmatically the layer transparency.
>> I used the following code:
>> layer.setTransparency(80)
>> This works only if I want to see layers which are under the active one
>> but it does not work for the features inside active layer.
>> When there are identical polygons which overlap within active layer, I
>> can only see the top one. If I select a polygon which is underneath it
>> is not displayed as selected.
>> I can make it work if I manually open the layer style and double click
>> on rule to open Rule properties and set the transparency for the rule.
>> How can I change the rule transparency programmatically?
>> Thank you,
>> Marian
>> This electronic message, as well as any transmitted files included in
>> the electronic message, may contain privileged or confidential
>> information and is intended solely for the use of the individual(s) or
>> entity to which it is addressed. If you have received this electronic
>> message in error please notify the sender immediately and delete the
>> electronic message. Any unauthorized copying, disclosure or
>> distribution of the electronic message is strictly forbidden. NAV
>> CANADA accepts no liability for any damage caused by any virus and/or
>> other malicious code transmitted by this electronic communication.
>> Le présent message électronique et tout fichier qui peut y être joint
>> peuvent contenir des renseignements privilégiés ou confidentiels
>> destinés à l’usage exclusif des personnes ou des organismes à qui ils
>> s’adressent. Si vous avez reçu ce message électronique par erreur,
>> veuillez en informer l’expéditeur immédiatement et supprimez le. Toute
>> reproduction, divulgation ou distribution du présent message
>> électronique est strictement interdite. NAV CANADA n’assume aucune
>> responsabilité en cas de dommage causé par tout virus ou autre
>> programme malveillant transmis par ce message électronique.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
