[Qgis-user] QGIS 2.18 -Changing layer rule-based style transparency
    Tudorache, Marian
    Marian.Tudorache at navcanada.ca
    Wed Jan  9 10:38:25 PST 2019
In 2.18 it crush at this line
symbol = symbolItem.symbol()
You should have symbol2() not symbol().
symbol = symbolItem.symbol2()
Thank you,
Marian
-----Original Message-----
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Raymond Nijssen
Sent: Saturday, January 5, 2019 11:04 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS 2.18 -Changing layer rule-based style transparency
Already got it working, using the setLegendSymbolItem() on the renderer:
layer = iface.activeLayer()
renderer = layer.renderer()
symbolItems = renderer.legendSymbolItems()
for symbolItem in symbolItems:
     print(symbolItem)
     color = symbol.color()
     color.setAlpha(255 * 0.8)
     symbol.setColor(color)
     renderer.setLegendSymbolItem(symbolItem.ruleKey(), symbol)
layer.triggerRepaint()
No clue if it will run in 2.18, expecting not. Hoping you can upgrade.
Raymond
On 05-01-19 13:22, Raymond Nijssen wrote:
> Hi Marian,
> As I understand you want to set every symbol in your rule based
> classification to 80% transparent (instead of the entire layer)?
> I tried to write a qgis (v3.4) script but unfortunately it crashes my
> qgis. So I hope somebody here can correct it, or maybe you will find
> the solution yourself.
> I'm doing many prints to see the return values. The crash happens when
> in line 18: symbolItem.setSymbol(symbol)
> print(symbolItems)
>      print('---')
>      print(symbolItem)
>      print(symbol)
>      print(color.name(1))
>      color.setAlpha(255*0.8)
>      symbolItem.setSymbol(symbol) # !!! this makes qgis crash
> When crashing, qgis outputs:
> QGIS died on signal 11Could not attach to process.  If your uid
> matches the uid of the target process, check the setting of
> /proc/sys/kernel/yama/ptrace_scope, or try again as the root user.
> For more details, see /etc/sysctl.d/10-ptrace.conf
> ptrace: Operation not permitted.
> No thread selected
> No stack.
> gdb returned 0
> Aborted (core dumped)
> Kind regards,
> Raymond
> On 04-01-19 22:32, Tudorache, Marian wrote:
>> Hi,
>> I have a polygon type vector layer with rule-based style.
>> I need to change programmatically the layer transparency.
>> I used the following code:
>> layer.setTransparency(80)
>> This works only if I want to see layers which are under the active
>> one but it does not work for the features inside active layer.
>> When there are identical polygons which overlap within active layer,
>> I can only see the top one. If I select a polygon which is underneath
>> it is not displayed as selected.
>> I can make it work if I manually open the layer style and double
>> click on rule to open Rule properties and set the transparency for the rule.
>> How can I change the rule transparency programmatically?
>> Thank you,
>> Marian
>> This electronic message, as well as any transmitted files included in
>> the electronic message, may contain privileged or confidential
>> information and is intended solely for the use of the individual(s)
>> or entity to which it is addressed. If you have received this
>> electronic message in error please notify the sender immediately and
>> delete the electronic message. Any unauthorized copying, disclosure
>> or distribution of the electronic message is strictly forbidden. NAV
>> CANADA accepts no liability for any damage caused by any virus and/or
>> other malicious code transmitted by this electronic communication.
>> Le présent message électronique et tout fichier qui peut y être joint
>> peuvent contenir des renseignements privilégiés ou confidentiels
>> destinés à l’usage exclusif des personnes ou des organismes à qui ils
>> s’adressent. Si vous avez reçu ce message électronique par erreur,
>> veuillez en informer l’expéditeur immédiatement et supprimez le.
>> Toute reproduction, divulgation ou distribution du présent message
>> électronique est strictement interdite. NAV CANADA n’assume aucune
>> responsabilité en cas de dommage causé par tout virus ou autre
>> programme malveillant transmis par ce message électronique.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
