[Qgis-user] Building Qgis Server only
Henrik Uggla
Henrik.Uggla at kristianstad.se
Mon Jan 7 02:44:17 PST 2019
Hi Andreas!
I really can't see why Qgis Server would need X. If I build Qgis Server on a server with X, will the resulting package work on a server without X?
It would be very helpful if you could share your configuration with me.
Regards,
Henrik
________________________________________
Från: Andreas Neumann <a.neumann at carto.net>
Skickat: den 7 januari 2019 11:26
Till: Henrik Uggla
Kopia: qgis-user at lists.osgeo.org
Ämne: Re: [Qgis-user] Building Qgis Server only
Hi Henrik,
You can now build QGIS Server without desktop, but not without X. You still need X for PDF generation (GetPrint command).
If you are interested, I have docker configurations for QGIS Server 2.x. and 3.x based on Ubuntu and NginX server. Still struggling a bit with NGinX URL forwarding, but hoping to solve it tomorrow with the help of Marco B.
I could share the configuration, if it helps for you.
Greetings,
Andreas
On 2019-01-07 11:01, Henrik Uggla wrote:
I would like to create a Qgis Server Docker container based on Alpine. Is it possible to build Qgis Server, without the desktop applications, on a server that doesn't run X?
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
