[Qgis-user] After deleting points, attribute rows persist
Andreas Neumann
a.neumann at carto.net
Mon Jan 7 07:25:19 PST 2019
Hi Micha,
hm - interesting.
I have to say that deleting features by using the node tools seems a bit
"unconventional" to me. There is a "delete features" tool, which is
meant to be used to delete features. The node tools serves a different
purpose: to remove nodes.
I am not sure it is well defined that removing a point using the node
tool should also remove the feature. It might be a valid behavior of
QGIS that it sets to the geometry to "NULL" and not delete the feature
after the last node of a geometry was removed.
Are you sure that this really worked in the past?
Andreas
On 2019-01-07 16:15, Micha Silver wrote:
> Hi Alex:
> Linux Mint 19
> gdal 2.2.3
> QGIS 3.4.3
> Just out of curiosity, I did the same on a debian buster machine (QGIS 2.18) and found the same: deleting vertices (with the node tool) on a point vector layer does not delete the attribute rows.
> On 1/6/19 11:38 PM, Alexandre Neto wrote: What's your platform?
> What's the version of gdal?
> Thanks,
> Alex Neto
> A dom, 6/01/2019, 12:55, Micha Silver <tsvibar at gmail.com> escreveu:
> I have found that after deleting some points in both a shapefile and a geopackage layer, the attribute rows remain in the table (with null geometry). Is this expected? I'm using 3.4.3, and I don't remember that being so in earlier versions.
> I removed the "phantom" rows by selecting by expression: '$geometry is null' and then deleting. Still the behavior was surprising. I hope this is not a resurrection of https://issues.qgis.org/issues/11007 ??
> Thanks
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
> Qgis-user mailing list
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user --
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com http://gisunchained.wordpress.com
Micha Silver
Ben Gurion Univ.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190107/258451ef/attachment.html>
