[Qgis-user] After deleting points, attribute rows persist
Bernhard Ströbl
bernhard.stroebl at jena.de
Mon Jan 7 07:47:16 PST 2019
Maybe the node tool shouldn't be available when editing a point layer?
Anything one may want to do with points can be done using the other
tools (move, delete part). I was always wondering why it is there
because AFAIU nodes are not individual features, they only exist as part
of a line or polygon boundary, but points in a point layer are
individual features themselves.
Bernhard
Am 07.01.2019 um 16:25 schrieb DelazJ:
> Hi Micha,
> The Node Tool is not meant to remove features, but to edit/remove their
> geometries. Your feature persists in your dataset through their
> attributes and you can later use the "Add part" tool to create a new
> geometry.
> https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#vertex-tool
> For full deletion (data + geometry), you should use the the "Delele
> selected" tool, with a red bin.
> Regards,
> Harrissou
> Le lun. 7 janv. 2019 à 16:15, Micha Silver <tsvibar at gmail.com
> <mailto:tsvibar at gmail.com>> a écrit :
> Hi Alex:
> Linux Mint 19
> gdal 2.2.3
> QGIS 3.4.3
> Just out of curiosity, I did the same on a debian buster machine
> (QGIS 2.18) and found the same: deleting vertices (with the node
> tool) on a point vector layer does not delete the attribute rows.
> On 1/6/19 11:38 PM, Alexandre Neto wrote:
>> What's your platform?
>> What's the version of gdal?
>> Thanks,
>> Alex Neto
>> A dom, 6/01/2019, 12:55, Micha Silver <tsvibar at gmail.com
>> <mailto:tsvibar at gmail.com>> escreveu:
>> I have found that after deleting some points in both a
>> shapefile and a geopackage layer, the attribute rows remain in
>> the table (with null geometry). Is this expected? I'm using
>> 3.4.3, and I don't remember that being so in earlier versions.
>> I removed the "phantom" rows by selecting by expression:
>> '$geometry is null' and then deleting. Still the behavior was
>> surprising. I hope this is not a resurrection of
>> https://issues.qgis.org/issues/11007 ??
>> Thanks
>> Micha Silver
>> Ben Gurion Univ.
>> Sde Boker, Remote Sensing Lab
>> cell: +972-523-665918
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Alexandre Neto
>> @AlexNetoGeo
>> http://sigsemgrilhetas.wordpress.com
>> http://gisunchained.wordpress.com
> Micha Silver
> Ben Gurion Univ.
__________ Information from ESET Mail Security, version of virus signature database 18665 (20190107) __________
The message was checked by ESET Mail Security.
http://www.eset.com
