[Qgis-user] [Qgis-community-team] training manual QGIS 3
Janneke van Dijk
janneke.qgis at gmail.com
Wed Jan 9 09:46:30 PST 2019
Hi Alexandre and Harrissou (and others),
I'm trying to feel my way through the contribution thing and github by
starting with some small remarks/changes I suggested myself. I think I
have just made an edit and created a pull request - it tells me 'This
branch has no conflicts with the base branch'. Not sure how to proceed
from here. Is this enough from my side?
Thanks for some guidance....
Janneke
On 07/01/2019 23:27, Alexandre Neto wrote:
> Screenshots shouldn't be a blocker, you can take screenshots using
> windows. Then, if we have time, we can replace windows screenshots later.
> A seg, 7/01/2019, 18:17, Janneke van Dijk <janneke.qgis at gmail.com
> <mailto:janneke.qgis at gmail.com>> escreveu:
> Yes, I would be up for learning how to do it. I remember once upon
> a time trying to get started and somehow getting stranded before I
> got anywhere. Partly because I couldn't get linux to work on VM on
> my laptop so I couldn't do the screen shots.
> On 07/01/2019 17:39, Alexandre Neto wrote:
>> Some of those changes are quite small. Would you be interested in
>> learning how to fix it yourself?
>> A seg, 7/01/2019, 14:37, Alexandre Neto <senhor.neto at gmail.com
>> <mailto:senhor.neto at gmail.com>> escreveu:
>> Actually, someone already did it. Thanks!!
>> <senhor.neto at gmail.com <mailto:senhor.neto at gmail.com>> escreveu:
>> I can do it.
>> A seg, 7/01/2019, 13:43, Janneke van Dijk
>> <janneke.qgis at gmail.com <mailto:janneke.qgis at gmail.com>>
>> escreveu:
>> I've registered all that I've noticed, I just didn't
>> manage to tag them with training manual. Should I do
>> that or is that someone else who adds the labels?
>> Janneke
>> On 07/01/2019 00:42, Alexandre Neto wrote:
>>> Better duplicated issues than missing ones . So
>>> please report whatever you feel that is a bug, or a
>>> possible improvement. That way we won't forget.
>>> Thanks!
>>> A dom, 6/01/2019, 10:07, Janneke van Dijk
>>> Hi Harrissou,
>>> Getting ready to at least list my observations.
>>> Do I understand it correctly that whatever is
>>> not mentioned in [2] is not being addressed?
>>> Quite a few of my remarks will also related to
>>> updating screenshots, which I think has also
>>> been mentioned as a general issue somewhere -
>>> should I still list them separately?
>>> Thanks for your assistance,
>>> Janneke
>>> On 05/01/2019 13:33, DelazJ wrote:
>>>> Hi Janneke,
>>>> Thanks for your tests. And indeed the training
>>>> manual update is a work in progress and maybe
>>>> could you publish your remarks as issue reports
>>>> in the doc repository [0] so that we took them
>>>> into consideration as we go.
>>>> You are right about the missing data, there was
>>>> a pull request [1] to integrate these data we
>>>> forgot to merge. Done now! Download the dataset
>>>> again, please.
>>>> Note that we are reviewing initial lessons and
>>>> have some pending updates for both lessons [2]
>>>> and corresponding data [3]. Tests and feedbacks
>>>> are more than welcome. Thanks!
>>>> [0]
>>>> https://github.com/qgis/QGIS-Documentations/issues
>>>> [1]
>>>> https://github.com/qgis/QGIS-Training-Data/pull/15
>>>> [2]
>>>> https://github.com/qgis/QGIS-Documentation/pulls?q=is%3Apr+is%3Aopen+label%3A%22Training+Manual%22
>>>> [3]
>>>> https://github.com/qgis/QGIS-Training-Data/pull/17
>>>> Regards,
>>>> Harrissou
>>>> Le jeu. 3 janv. 2019 à 13:22, Janneke van Dijk
>>>> <mailto:janneke.qgis at gmail.com>> a écrit :
>>>> Dear all,
>>>> I'm currently going through the QGIS 3
>>>> training manual
>>>> (https://docs.qgis.org/testing/en/docs/training_manual/)
>>>> using QGIS
>>>> 3.4.3 and documenting any changes that
>>>> would still need attention. I
>>>> understand that it's a work in progress
>>>> and hope/plan to contribute a
>>>> bit in a later stage. What is complicating
>>>> matters is that the data that
>>>> I downloaded (QGIS-Training-Data-2.0.zip)
>>>> does not contain all the
>>>> layers that are mentioned (so far schools,
>>>> restaurants, network_analysis
>>>> folder and possibly some more that I may
>>>> have skipped). Is there a
>>>> complete/up-to-date data set available?
>>>> Where can I find it?
>>>> Thanks for any suggestions,
>>>> Janneke
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> <mailto:Qgis-user at lists.osgeo.org>
>>>> List info:
>>>> https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe:
>>> Qgis-community-team mailing list for organizing
>>> community resources such as documentation,
>>> translation etc..
>>> Qgis-community-team at lists.osgeo.org
>>> <mailto:Qgis-community-team at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
>>> Alexandre Neto
>>> @AlexNetoGeo
>>> http://sigsemgrilhetas.wordpress.com
>>> http://gisunchained.wordpress.com
>> Alexandre Neto
>> @AlexNetoGeo
>> Alexandre Neto
>> @AlexNetoGeo
>> Alexandre Neto
>> @AlexNetoGeo
> Alexandre Neto
> @AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190109/59246cbc/attachment.html>
