[Qgis-user] resolved QGIS 3 - Deactivate "boxes" around labels
Anna Hujber
anna at hesse-hujber.de
Thu Jan 10 00:31:20 PST 2019
Dear Nyall,
thanks for the fast and easy help. There was no "draw label candidates"
option in that tab u described (named "Automated Placement Engine") but
I clicked on "Restore Defaults" which deactivated an option called "show
candidates (for debugging)" and resolved my problem. Maybe the "draw
label candidates" option has been renamed?
Thanks again,
Anna
On 10.01.19 09:19, Nyall Dawson wrote:
> On Thu., 10 Jan. 2019, 18:13 Anna Hujber <anna at hesse-hujber.de
> <mailto:anna at hesse-hujber.de> wrote:
> Hey community,
> I use 3.4.3-Madeira on a Ubuntu 18.04.1 LTS.
> I was modifying labels on a map when several rectangles appeared
> around and next to the labels. I ignored them first cuz I was busy
> working on making a label appear again I had hidden before and
> thought the display of boxes belonged to one of the labeling tools
> I was working with. When I had arranged my issue, I intended to
> deactivate the rectangles that had appeared around all labels of
> all layers, assuming that I had somehow somewhere clicked on a
> special view option. However, until now I was not able to figure
> out what those boxes are, how I had made them appear in first
> place and how to get rid of them again.
> They also show up in the print layout and on the exported pdf.
> When I click on "new map view", though, they are not shown in the
> new view. Deactivating labels and reactivating them did not change
> anything. Moreover, it is something that applies to all layers, so
> modifying a specific layer's label options should not bring any
> solution.
> From the label setting for one of your layers, look for the little
> button in the top right which has a blue/yellow four arrow symbol.
> Click that, and then uncheck "draw label candidates"
> Nyall
> Thank you,
> Anna
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190110/16bef6e3/attachment.html>
