[Qgis-user] How to fix 'Could not find the Qt platform plugin “Windows” in “”' when implementing qgis in custom Python3 application?
    Matt Brauer
    jbrauer90 at gmail.com
    Thu Jan 10 13:44:08 PST 2019
I am implementing qgis 3.4.3 in a custom application, but when I
instantiate the QgsApplication() class, I receive the error "Could not find
the Qt platform plugin "Windows" in "".
I've attempted using various installs of qgis 3.x+ including the standalone
installer and OSGeo4W web installer. I currently am sticking with the
OSGeo4W web installer installation. I am using a Python 3.7 installation
separate from what comes with OSGeo4W and attempting to integrate qgis
functionality.
I have followed the instructions in the following QGIS help doc under the
section: "Using PyQGIS in Custom Applications"
https://docs.qgis.org/2.18/en/docs/pyqgis_developer_cookbook/intro.html#run-python-code-when-qgis-starts
After attempting to run the script I realized a dll plugin was missing.
After some research, I found its the qwindows.dll that qt uses. The
qwindows.dll is included in the OSGeo4W installation under:
C:\OSGeo4W\apps\Qt5\plugins\platforms
I changed the QT_PLUGIN_PATH variable on the local command prompt to
include the directory above, but the same error prevailed. I also changed
the QT_DEBUG_PLUGINS variable to 1 which printed out the locations Qt is
looking for plugins. Interestingly, it wasn't looking for plugins in the
path I specified in the QT_PLUGIN_PATH variable.
Python Code:
import sys#add qgis python libraries to instance python path in case
not added #at the environment variable %PYTHONPATH% level
sys.path.extend(['C:\\OSGeo4W\\apps\\qgis\\python',
'C:\\OSGeo4W\\apps\\Python37\\Lib\\site-packages'])
from qgis.core import *
# supply path to qgis install
locationQgsApplication.setPrefixPath('C:\\OSGeo4W\\apps\\qgis', True)
# create a reference to the QgsApplication# setting the second
argument to True enables the GUI, which we need to do# since this is a
custom application
qgs = QgsApplication([], True)
# load providers
qgs.initQgis()
# Write your code here to load some layers, use processing algorithms, etc.
# When your script is complete, call exitQgis() to remove the provider
and# layer registries from memory
qgs.exitQgis()
Batch File Code to Start Cmd Prompt with Proper Variables:
@echo off
SET OSGEO4W_ROOT=C:\OSGeo4W::Include environment variables set by qgis
on startup
call %OSGEO4W_ROOT%\bin\o4w_env.bat
call %OSGEO4W_ROOT%\bin\qt5_env.bat
call %OSGEO4W_ROOT%\bin\py3_env.bat at echo off
path %PATH%;%OSGEO4W_ROOT%\apps\qgis\bin
path %PATH%;C:\OSGeo4W\apps\Qt5\bin
path %PATH%;C:\OSGeo4W\apps\Python37\Scripts
set PYTHONPATH=%PYTHONPATH%;%OSGEO4W_ROOT%\apps\qgis\python
set PYTHONHOME=%OSGEO4W_ROOT%\apps\Python37
set QT_PLUGIN_PATH=%OSGEO4W_ROOT%\apps\Qt5\plugins;%OSGEO4W_ROOT%\apps\qgis\qtplugins
set QT_DEBUG_PLUGINS=1
cmd.exe
I expect to run the python script and receive no errors since I'm pointing
to the directory where the qwindows.dll missing plugin is stored. However,
I am still receiving the missing windows plugin error.
Here is the actual message with QT_DEBUG_PLUGINS set to 1:
QFactoryLoader::QFactoryLoader() checking directory path
"C:/OSGeo4W/apps/qgis/qtplugins/platforms" ...
"C:/OSGeo4W/apps/Python37/platforms" ... qt.qpa.plugin: Could not find the
Qt platform plugin "windows" in "" This application failed to start because
no Qt platform plugin could be initialized. Reinstalling the application
may fix this problem.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190110/a6d7bb38/attachment.html>
