[Qgis-user] Vector Affine trouble
Mike Shand Mike.Shand at glasgow.ac.uk
Sun Jan 13 07:29:41 PST 2019
Hi Rutger,
If you have successfully converted your Adobe Illustrator file into an
ESRI shapefile (using Avenza MaPublisher or DXf export ?) please first
check the quality of the linework in QGIS.  Any Illustrator vector
bezier curves will probably have been simplified to straight lines.  To
avoid the lines being too generalised use the Add Anchor Points option
in Illustrator several times if necessary to ensure the curves are
replicated by short straight line sections.
If you are using MaPublisher
<http://download.avenza.com/Downloads/Docs/MAPublisher/MP90_TutorialGuide.pdf>
there is the option to add the projection/datum.
Another alternative using Dxf format is:
http://christopherwesson.azurewebsites.net/2016/04/08/importing-vectors-from-illustrator-into-a-gis-with-georeferencing/#sthash.O3XCCqoR.dpbs
Regards,
Mike
On 12/01/2019 22:37, Rutger Emmelkamp wrote:
> Hello everybody,
> Hope someone can help me out this Saturday night (or Sunday or Monday) but no hurry!
> How to georeference an Illustrator vector image (contour line map) from a specific area?
> I have qgis 3.4.3 installed and qgisAffine and Vector Blender plugins don’t work for this version.
> I managed to turn the file into a .shp file and I see it somewhere off the coast of Ghana (coordinates 0,0) but how do I drag it into place?
> I think I’m looking for a Vector Affine Transformation plugin or menu but can’t find it.
> Hope someone can help me in the right direction.
> Thanks and have a nice weekend.
> Rutger
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190113/a2c92136/attachment.html>
