[Qgis-user] Using SAGA Terrain Analysis - Hydrology
elcin tan elcintan at gmail.com
Tue Jan 22 03:17:36 PST 2019
Hello All,
I had the same problem and I solved it with the help of William.
I installed the versions of both 2.1 and 2.2 of GDAL which SAGA uses and
then I made a clean installation for QGIS3.4.
Hope it helps.
Best,
Elçin
On Mon, Jan 21, 2019 at 8:04 PM Anthony Greenish <agreenish at bluewin.ch>
wrote:
> Hello
> I run into the following message “The following layers were not correctly
> generated.<ul><li>C:/Users/Anthony/AppData/Local/Temp/processing_183557c8d1b344aeaa17804e3e8d37dd/1bdc3ccd923b4634ad39d66b09203797/FILLED.sdat</li></ul>You
> can check the 'Log Messages Panel' in QGIS main window to find more
> information about the execution of the algorithm.” When I try to run the
> Fill sinks algorithm in Saga. I am running QGis 3.2.1 in Win 10. I’ve tried
> to find the log/report in “QGis main window “ but with no luck. Any help in
> sorting out what the problem is would be very appreciated.
> Thanks
> greeton
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190122/1829c8b6/attachment.html>
