[Qgis-user] Using SAGA Terrain Analysis - Hydrology
Alexander Bruy
alexander.bruy at gmail.com
Tue Jan 29 10:22:50 PST 2019
Hi Lene,
this was intended change to prevent possible data loss during format conversion
and interpolation.
вт, 29 січ. 2019 о 20:21 Lene Fischer <lfi at ign.ku.dk> пише:
> Hi Nyall,
> Why is it only possible to save the raster as a SDAT. Previously we could save as TIF.
> Regards
> Lene
> Fra: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Philip Barlow
> Sendt: 22. januar 2019 14:02
> Til: Anthony Greenish
> Cc: qgis-user at lists.osgeo.org
> Emne: Re: [Qgis-user] Using SAGA Terrain Analysis - Hydrology
> Hi Anthony,
> SAGA outputs SDAT grids that can be opened in QGIS, just drag and drop onto the canvas. You can convert them to whatever format you prefer after that.
> Phil
> From: Anthony Greenish [mailto:agreenish at bluewin.ch]
> Sent: 22 January 2019 12:59
> To: Philip Barlow
> Subject: RE: [Qgis-user] Using SAGA Terrain Analysis - Hydrology
> I tried your suggestion and did the Fill function in Saga which worked. The problem is how do I take the grids created into QGis?
> From: Philip Barlow [mailto:philipb at pembrokeshirecoast.org.uk]
> Sent: 22 January 2019 09:07
> To: Christophe Bayle; Anthony Greenish
> Hi Anthony,
> A temporary work around would be fire up SAGA itself and run fill sinks from there? Then heading back into QGIS or, if you can, completing the rest of your workflow there. I’ve had the exact same error before and similar errors when trying to use some of the other tools in the past but the processes have always worked in SAGA.
> Phil
> From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Christophe Bayle
> Sent: 21 January 2019 17:12
> To: Anthony Greenish
> Subject: Re: [Qgis-user] Using SAGA Terrain Analysis - Hydrology
> Hi Anthony,
> Got exactly the same problem few days ago trying to use these tools as well.
> The only work around i found was to install an older version of QGIS. (3.4.2 worked for a while, but then i got the same error.... so i finished using 2.18)
> Please let me know if you end up understanding the issue :)
> All the best,
> C.
> On Mon, Jan 21, 2019 at 6:04 PM Anthony Greenish <agreenish at bluewin.ch> wrote:
> Hello
> I run into the following message “The following layers were not correctly generated.<ul><li>C:/Users/Anthony/AppData/Local/Temp/processing_183557c8d1b344aeaa17804e3e8d37dd/1bdc3ccd923b4634ad39d66b09203797/FILLED.sdat</li></ul>You can check the 'Log Messages Panel' in QGIS main window to find more information about the execution of the algorithm.” When I try to run the Fill sinks algorithm in Saga. I am running QGis 3.2.1 in Win 10. I’ve tried to find the log/report in “QGis main window “ but with no luck. Any help in sorting out what the problem is would be very appreciated.
> Thanks
> greeton
> Qgis-user mailing list
> Christophe Bayle
> Ecumène Cartographie
> Email: christophe at ecumene.fr
> Tél: +33 6.64.91.64.85
> Mae'r Awdurdod yn hapus i gyfathrebu yn Gymraeg neu yn Saesneg
> The Authority is happy to communicate in Welsh or English
> Website www.pembrokeshirecoast.org.uk
> Follow us on Twitter
> Join us on Facebook
> Watch us on Youtube
> Look at us on Flickr
> This email and any attached files should only be read by those persons to whom
> they are addressed and be used by them only for their intended purpose.
> If you are not the intended recipient please destroy all copies and inform the
> sender by return email.
> Please note that the contents of this email may be subject to public disclosure
> under the Freedom of Information Act 2000 and therefore the confidentiality of
> this message and any reply cannot be guaranteed.
> Click here to view PCNPA Privacy Notice Keeping your Information Safe
> For further information on the PCNPA please visit our website at www.pembrokeshirecoast.org.uk
> Please consider the environment before printing this email.
> Dim ond y personau hynny yr anfonwyd yr e-bost hwn atynt ac unrhyw ffeiliau sydd
> ynghlwm ddylid eu darllen, a dim ond hwy ddylid eu defnyddio at y diben y bwriadwyd hwy.
> Os nad y chi yw'r person y bwriadwyd eu derbyn a fyddech gystal ⠤inistrio pob copi a rhoi
> gwybod i'r anfonwr gyda throad yr e-bost.
> Noder os gwelwch yn dda y gall cynnwys yr e-bost hwn orfod cael ei ddatgelu i'r cyhoedd o
> dan Deddf Rhyddid Gwybodaeth 2000 ac felly ni ellir gwarantu cyfrinachedd y neges hon
> nac unrhyw ateb.
> Cliciwch yma i weld Hysbysiad Preifatrwydd APCAP - Cadw eich Gwybodaeth yn Ddiogel
> Am ragor o wybodaeth am APCAP ymwelwch ⧮ gwefan ar www.arfordirpenfro.org.uk
> Ystyrier yr amgylchedd cyn argraffu'r e-bost hwn os gwelwch yn dda.
> Join us on Facebook
> Watch us on Youtube
> Click here to view PCNPA Privacy Notice � Keeping your Information Safe
> Os nad y chi yw'r person y bwriadwyd eu derbyn a fyddech gystal � dinistrio pob copi a rhoi
> nac unrhyw ateb.
> Am ragor o wybodaeth am APCAP ymwelwch �'n gwefan ar www.arfordirpenfro.org.uk
Alexander Bruy
