[Qgis-user] How to get a point's coordinate for GPS?
Etienne Trimaille
etienne.trimaille at gmail.com
Fri Jan 25 05:19:37 PST 2019
I will just add 2 tips to Raymond's answer.
* In the field calculator, you can create a "virtual" field, so the content
is updated everytime you move a point, or you create a new one.
* With these expressions, you will get decimal values. Since QGIS 3.4, you
can have DMS or DM values (convenient for GPS)
to_dms(x(transform( $geometry, 'EPSG:2444', 'EPSG:4326'))),'x', 3)
Le ven. 25 janv. 2019 à 07:25, Maria Shinoto <maria at shinoto.de> a écrit :
> Thanks Raymond,
> great to have an answer already this evening. I will check it out tomorrow
> and give feedback,
> Maria
> > Am 2019-01-25 um 20:16 schrieb Raymond Nijssen <r.nijssen at terglobo.nl>:
> > In qgis3 it should work like this:
> > On 25-01-19 11:49, Maria Shinoto wrote:
> >> Hi,
> >> I have been watching YouTube and reading tutorials the whole afternoon,
> but I do not get this simple task done:
> >> I have a map with several layers in EPSG:2444. Now I create another
> vector layer with points, which represents points that I have to go myself
> and check for several features. I will go there with my Garmin Etrex 10 GPS.
> >> So, I would like to
> >> - add the coordinates of the certain points into the attribute table to
> print out the table later.
> >> - create a file with the coordinates in order to import it into the GPS
> device and walk along all points.
> >> My question:
> >> 1. How do I get readable (GPS) coordinates into the attribute table
> (automatically, with field calculator or so)?
> > You can use the field calculator on your attribute table with the
> following expressions:
> > lon
> > lat
> > y(transform( $geometry, 'EPSG:2444', 'EPSG:4326'))
> >> 2. Can I export a GPX file or so from these coordinates to import into
> a Garmin device (if so, how?)
> > Right click your layer and export in GPX format. You might need to
> uncheck your lat and lon field to prevent getting an error.
> > Good luck!
> >> It seems so basic, but I do not succeed.
> >> Best,
> >> Maria
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190125/2b6ce649/attachment.html>
