[Qgis-user] OSGEO4W64 Installer installs Grass 7.6.0 but processing plugin and env variables point to 7.4.4.
Jürgen E. Fischer jef at norbit.de
Fri Jan 25 13:05:18 PST 2019
Hi Nicolas,
On Fri, 25. Jan 2019 at 14:49:33 -0500, Nicolas Cadieux wrote:
> I am trying to do a clean install of Qgis using the OSGeo4W64 installer.
> Before hand, I destroyed all QGIS registry keys, files, temporary files,
> user profiles, shortcuts...  It seem the installer installs QGIS 3.4.4 with
> GRASS 7.6.0.  However, Windows x_64 menu points to "QGIS Desktop 3.4.4 with
> GRASS 7.4.4" and not GRASS 7.6.0.  Now, if I install 7.4.4, It works but I
> would like to use 7.6.0. as it is the default for 2.18 also.
GRASS was updated after the QGIS release - hence it still expects 7.4.4.
Unfortunately the rebuilds I meanwhile failed because of bug in the new
GRASS package (requiring the 32bit install to be in C:\OSGeo4W32 and the 64bit
install to be in C:\OSGeo4W64 and failing otherwise).
I just fixed it locally and the builds are underway.
You can meanwhile downgrade GRASS or resort to the standalone installer, which
was built before the GRASS update.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190125/a1a943ff/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190125/a1a943ff/attachment.ksh>
