[Qgis-user] River Flood modelling
    Jonathan Moules
    jonathan-lists at lightpear.com
    Fri Jan 25 14:54:44 PST 2019
Hi Nicolas,
If you don't get a reply here that solves your issue it may be worth
asking on the GRASS mailing list. I know GRASS has a lot of hydrographic
tools and it's integrated into QGIS so...
https://lists.osgeo.org/mailman/listinfo/grass-user
Jonathan
On 2019-01-25 06:52, Nicolas Cadieux wrote:
> Hi,
> I know it can't be that simple but I would like to model a river flood
> in a mountainous area.  I am looking for something like the Saga Lake
> flood module with a LiDAR derived DEM, a seed but with the possibility
> to add X amount of water.  It's basically a lake and dam scenario and
> you just add water and figure out where the water goes down the valley
> when it goes over the dam.  Of course I can't use the normal lake
> flood modules because rivers are not flat therefore I need something
> that takes the downhill valley shape into consideration.  Also, I am
> not looking for a simple channel network map with lines and points.  I
> would like the actual polygon or raster representation of the 2D shape
> of the river channel.  Can you please point me in the right direction.
> Nicolas
> Qgis-user mailing list
