[Qgis-user] How to get a point's coordinate for GPS?
Raymond Nijssen
r.nijssen at terglobo.nl
Sat Jan 26 01:14:46 PST 2019
Hi Maria,
You are welcome! And thanks for reporting back.
Raymond
On 26-01-19 01:24, Maria Shinoto wrote:
> Calvin, Etienne, Raymond,
> Thank you all three for your answers.
> I tested the suggestions with my limited knowledge of QGIS and could use
> it very well. I can pursue my task now.
> For the records: The suggestions from Raymond worked all very well;
> Etiennes idea with the virtual field is an excellent idea for ongoing
> work, unfortunately the calculation example did not work for me -- but
> it is OK with the more basic solution. Finally, the lat-lon plugin as
> well as the POI Exporter seem to work seemlessly. I have now to learn
> about all the power of these plugins.
> Thanks again,
> Maria
>> Am 2019-01-25 um 23:29 schrieb C Hamilton <adenaculture at gmail.com
>> <mailto:adenaculture at gmail.com>>:
>> Maria,
>> You can certainly do it with the field calculator, but I wanted an
>> easier way. I programmed this capability into the Lat Lon Tools
>> <http://plugins.qgis.org/plugins/latlontools/>plugin. The specific
>> function is "Geometry to field". You can access it from "Plugins->Lat
>> Lon Tools->Conversions->Geometry to field" or from the processing
>> toolbox under Lat Lon tools.
>> There is a lot of functionality with this. You can export the the
>> points to either a single field in the attributes table with a
>> separator or to two fields. You can specify the output CRS. You can
>> also choose between Decimal degrees, DMS coordinates, GeoJSON, WKT,
>> MGRS, and Plus Codes.
>> As far as getting it onto your Garmin device try the POI Exporter
>> <http://plugins.qgis.org/plugins/poiexport/>plugin which is another
>> plugin I wrote. Look at the documentation. It will export your data in
>> GPX format and you can use Garmin Basecamp or the Garmin POI Loader to
>> get it onto your device.
>> Calvin
>> On Fri, Jan 25, 2019 at 5:49 AM Maria Shinoto <maria at shinoto.de
>> <mailto:maria at shinoto.de>> wrote:
>> Hi,
>> I have been watching YouTube and reading tutorials the whole
>> afternoon, but I do not get this simple task done:
>> I have a map with several layers in EPSG:2444. Now I create
>> another vector layer with points, which represents points that I
>> have to go myself and check for several features. I will go there
>> with my Garmin Etrex 10 GPS.
>> So, I would like to
>> - add the coordinates of the certain points into the attribute
>> table to print out the table later.
>> - create a file with the coordinates in order to import it into
>> the GPS device and walk along all points.
>> My question:
>> 1. How do I get readable (GPS) coordinates into the attribute
>> table (automatically, with field calculator or so)?
>> 2. Can I export a GPX file or so from these coordinates to import
>> into a Garmin device (if so, how?)
>> It seems so basic, but I do not succeed.
>> Best,
>> Maria
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Terglobo
Fahrenheitstraat 1
5223 BJ 's-Hertogenbosch
The Netherlands
+31 (0) 6 25 31 49 83
