[Qgis-user] How to get a point's coordinate for GPS?
Maria Shinoto
maria at shinoto.de
Fri Jan 25 16:24:43 PST 2019
Calvin, Etienne, Raymond,
Thank you all three for your answers.
I tested the suggestions with my limited knowledge of QGIS and could use it very well. I can pursue my task now.
For the records: The suggestions from Raymond worked all very well; Etiennes idea with the virtual field is an excellent idea for ongoing work, unfortunately the calculation example did not work for me -- but it is OK with the more basic solution. Finally, the lat-lon plugin as well as the POI Exporter seem to work seemlessly. I have now to learn about all the power of these plugins.
Thanks again,
Maria
> Am 2019-01-25 um 23:29 schrieb C Hamilton <adenaculture at gmail.com>:
> Maria,
> You can certainly do it with the field calculator, but I wanted an easier way. I programmed this capability into the Lat Lon Tools <http://plugins.qgis.org/plugins/latlontools/>plugin. The specific function is "Geometry to field". You can access it from "Plugins->Lat Lon Tools->Conversions->Geometry to field" or from the processing toolbox under Lat Lon tools.
> There is a lot of functionality with this. You can export the the points to either a single field in the attributes table with a separator or to two fields. You can specify the output CRS. You can also choose between Decimal degrees, DMS coordinates, GeoJSON, WKT, MGRS, and Plus Codes.
> As far as getting it onto your Garmin device try the POI Exporter <http://plugins.qgis.org/plugins/poiexport/>plugin which is another plugin I wrote. Look at the documentation. It will export your data in GPX format and you can use Garmin Basecamp or the Garmin POI Loader to get it onto your device.
> Calvin
> On Fri, Jan 25, 2019 at 5:49 AM Maria Shinoto <maria at shinoto.de <mailto:maria at shinoto.de>> wrote:
> Hi,
> I have been watching YouTube and reading tutorials the whole afternoon, but I do not get this simple task done:
> I have a map with several layers in EPSG:2444. Now I create another vector layer with points, which represents points that I have to go myself and check for several features. I will go there with my Garmin Etrex 10 GPS.
> So, I would like to
> - add the coordinates of the certain points into the attribute table to print out the table later.
> - create a file with the coordinates in order to import it into the GPS device and walk along all points.
> My question:
> 1. How do I get readable (GPS) coordinates into the attribute table (automatically, with field calculator or so)?
> 2. Can I export a GPX file or so from these coordinates to import into a Garmin device (if so, how?)
> It seems so basic, but I do not succeed.
> Best,
> Maria
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190126/67a0d584/attachment.html>
