[Qgis-user] River Flood modelling
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Sat Jan 26 11:23:47 PST 2019
AnuGA results are now fully supported in QGIS 3.5 mesh layer. You can load
the SWW file directly.
In addition, you can look into HEC RAS, the 2-dimensional results can again
be loaded directly as a mesh layer in QGIS. There is also RiverGIS plugin
which helps you build your model.
Regards
Saber
On Sat, 26 Jan 2019 at 18:49, Tim Sutton <tim at kartoza.com> wrote:
> Hi
> Maybe you want to check out ANUGA too…. https://anuga.anu.edu.au
> Regards
> Tim
> On 25 Jan 2019, at 08:52, Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
> wrote:
> Hi,
> I know it can't be that simple but I would like to model a river flood in
> a mountainous area. I am looking for something like the Saga Lake flood
> module with a LiDAR derived DEM, a seed but with the possibility to add X
> amount of water. It's basically a lake and dam scenario and you just add
> water and figure out where the water goes down the valley when it goes over
> the dam. Of course I can't use the normal lake flood modules because
> rivers are not flat therefore I need something that takes the downhill
> valley shape into consideration. Also, I am not looking for a simple
> channel network map with lines and points. I would like the actual polygon
> or raster representation of the 2D shape of the river channel. Can you
> please point me in the right direction.
> Nicolas
> Qgis-user mailing list
> *Tim Sutton*
> tim at qgis.org
Saber Razmjooei
www.lutraconsulting.co.uk
+44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190126/28765795/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190126/28765795/attachment-0001.png>
