[Qgis-user] River Flood modelling
Tim Sutton
tim at kartoza.com
Sat Jan 26 10:48:39 PST 2019
Hi
Maybe you want to check out ANUGA too…. https://anuga.anu.edu.au
Regards
Tim
> On 25 Jan 2019, at 08:52, Nicolas Cadieux <nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> I know it can't be that simple but I would like to model a river flood in a mountainous area. I am looking for something like the Saga Lake flood module with a LiDAR derived DEM, a seed but with the possibility to add X amount of water. It's basically a lake and dam scenario and you just add water and figure out where the water goes down the valley when it goes over the dam. Of course I can't use the normal lake flood modules because rivers are not flat therefore I need something that takes the downhill valley shape into consideration. Also, I am not looking for a simple channel network map with lines and points. I would like the actual polygon or raster representation of the 2D shape of the river channel. Can you please point me in the right direction.
> Nicolas
> Qgis-user mailing list
Tim Sutton
tim at qgis.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190126/2dacf723/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190126/2dacf723/attachment.png>
