[Qgis-user] Problems QGIS 3.4 - Size fount and export to PDF - Help
Wilmer Orlando Martinez Bojaca
womartinezb at unal.edu.co
Tue Jan 29 17:26:50 PST 2019
Hi!
I was using the 3.2.2 version but last night I tried with the installer version 3.4.4 (Phyton 3.6.8) and the QGIS run perfect. I can change the font in the legend and export to PDF without any problem.
Thanks for the help,
Orlando
> On Jan 28, 2019, at 7:23 PM, Nicolas Cadieux <nicolas.cadieux at archeotec.ca> wrote:
> Hi Niall,
> Just to be clear, my problems were only on the layout window. It was ok when I exported it to PDF.
> Windows 10 OSGeo4w64.
> Nicolas
>> Le 28 janv. 2019 à 18:53, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
>> On Sun, 27 Jan 2019 at 12:42, Wilmer Orlando Martinez Bojaca
>> <womartinezb at unal.edu.co> wrote:
>>> Hi!
>>> Well, with which resolution you export the layout?
>>> In my case when I change the fount on the project window, the change immediately can see it on the layout window, but when I try change the fount in the legend on the layout window, anything change. I try too restart the software but happen the same thing, the fount doesn´t change.
>>> I have Mojave Mac 64x.
>> Which OSX installer are you using?
>> Nyall
>>>> On Sat, Jan 26, 2019 at 9:33 PM Nicolas Cadieux <nicolas.cadieux at archeotec.ca> wrote:
>>>> Windows 10 64, fresh QGIS install with OSGeo4w64 with latest version (not nightly build)
>>>> Nicolas
>>>>> Le 26 janv. 2019 à 21:31, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
>>>>> On Sun, 27 Jan 2019 at 12:16, Nicolas Cadieux
>>>>>> Hi,
>>>>>> I just noticed today that changing the font type and size does not change in the layout window even after a refresh. I do see it if I export it as a PDF. Looks like a bug...
>>>>> Are you on OSX?
>>>>> Nyall
>>>>>> Nicolas
>>>>>> Le 26 janv. 2019 à 19:16, Wilmer Orlando Martinez Bojaca <womartinezb at unal.edu.co> a écrit :
>>>>>> Hi everyone!
>>>>>> I have two problems with my QGIS, it looks so simple
>>>>>> 1. When I try to change the fount size in the legend, the program doesn't works. Thats mean, I can change the size (i.e. 12 to 10) but when I accept (press ok) the size is the same. I'm tried many times but never change anything.
>>>>>> 2. When I try to export the project to PDF, the final document appear empty (is a blank sheet) without any information, absolutely nothing. In this step I always select print like raster with 3000 ppp like export resolution.
>>>>>> I have QGIS 3.4 on Mac.
>>>>>> Anybody could help me please? Maybe is a simple set up.
>>>>>> Gracias. Saludos,
>>>>>> Orlando Martínez Bojacá
>>>>>> Profesional Especializado - Proyectos Productivos - FENSUAGRO
>>>>>> Zootecnista - Universidad Nacional de Colombia
>>>>>> Candidato MSc en Geomática - Universidad Nacional de Colombia
>>>>>> Tel. +57 3505731220
>>>>>> Skype. womartinezb
>>>>>> Linkedin. Orlando Martínez Bojacá
>>>>>> Antes de imprimir este correo piense bien si es necesario hacerlo. ¡El medio ambiente es cosa de todos!
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
