[Qgis-user] can't find processing in QGIS 3.4.4 LTR
    Janneke van Dijk
    janneke.qgis at gmail.com
    Thu Jan 31 22:15:07 PST 2019
Hi Saulteau,
I had looked in Panels and it didn't show up there. I ended up
uninstalling 3.4.4, reinstalling 3.4.3 (because I needed to finish
something using processing), and then uninstalling 3.4.3 and
reinstalling 3.4.4 - intending to test your other suggestions - but this
time the processing menu was back and all worked. I have no idea what
happened with the first installation, but anybody running into the same
issue can try reinstalling 3.4.4 first.
Thanks for the help!
Janneke
On 29/01/2019 21:46, Saulteau Don wrote:
> Hey Janneke,
> I use linux so the menus might be a little different for you.
> But at the top menus, look for Settings > Panels > Processing Toolbox
> Panel
> On Windows the Panels sub-menu might be in another place like View
> instead of Settings.
> Another easy way to turn on the processing toolbox is to right click
> on an empty space in the user interface (on a grey spot near another
> toolbar for example) and there is a menu that pops up with 'Processing
> Toolbox Panel' to toggle on and off.
> Lastly, the tools can be searched at the bottom left of QGIS (hotkey
> CTRL+K) which is what I tend to use quite a bit.
> On Tue, Jan 29, 2019 at 3:58 AM Janneke van Dijk
> <janneke.qgis at gmail.com <mailto:janneke.qgis at gmail.com>> wrote:
>     Dear list,
>     I have just downloaded the latest QGIS version for Windows (3.4.4
>     - LTR)
>     and it doesn't show the menu for processing. The plugin is active.
>     Any
>     idea if I need to do something to 'switch it on'?
>     thanks,
>     Janneke
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190201/5516e368/attachment.html>
