[Qgis-user] Using 3D map views with python console or in an atlas
Ryan Brook (Perth)
Ryan.Brook at advisian.com
Mon Jul 1 08:26:43 PDT 2019
Hi Bob,
Yes we also use ffmpeg to merge our frames into video.
To create ‘flat’ videos like your examples we generate visibility presets with a script then export them using a QGIS atlas. This is what we were hoping we would be able to do with 3D views but have not had any success.
Regards,
Ryan
From: Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us>
Sent: Monday, 1 July 2019 22:00
To: Ryan Brook (Perth) <Ryan.Brook at advisian.com>; QGIS Mailing List <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Using 3D map views with python console or in an atlas[External Sender]
Ryan,
Probably not what you were exactly looking for, but we’ve done something like this with MapServer and ffmpeg. the combination of these two pieces of software let you generate all sorts of things as you describe.
Here are some sample outputs:
https://www.dropbox.com/s/15c6awmbd57vw54/latest.webm?dl=0<https://urldefense.proofpoint.com/v2/url?u=https-3A__www.dropbox.com_s_15c6awmbd57vw54_latest.webm-3Fdl-3D0&d=DwMGaQ&c=Qznq1V5e4u04CfMRj920aPtDqN4RUEToMeZ6oK6t9iY&r=uiqzTG8TwLDffFCXwMoj3xc-xooTKMeCCK7zRJUQhc4&m=7oIhQMHLN-WS9xKnb0W7-5PT9nfqx-sECvi6bvCvM7c&s=aEvgR5V9jtQeXZLMX9enz7h_RNi4LU_VKSlsTyNDFto&e=>
https://www.dropbox.com/s/587w7jb2e6pew10/latest_activity.webm?dl=0<https://urldefense.proofpoint.com/v2/url?u=https-3A__www.dropbox.com_s_587w7jb2e6pew10_latest-5Factivity.webm-3Fdl-3D0&d=DwMGaQ&c=Qznq1V5e4u04CfMRj920aPtDqN4RUEToMeZ6oK6t9iY&r=uiqzTG8TwLDffFCXwMoj3xc-xooTKMeCCK7zRJUQhc4&m=7oIhQMHLN-WS9xKnb0W7-5PT9nfqx-sECvi6bvCvM7c&s=Yvnb7FUiCNKOusGYirENRzoVMgQt9Onnwlk9yRUDf9E&e=>
Note: Wait for this one, it’s a recording of 24hr of use of a map service. It’s short, but doesn’t show much until 6-7 am. It starts at midnight and chnages over the course of the day.
bobb
On Jun 29, 2019, at 3:47 AM, Ryan Brook (Perth) <Ryan.Brook at advisian.com<mailto:Ryan.Brook at advisian.com>> wrote:
Think Before You Click: This email originated outside our organization.
We have made some videos using frames exported from a 3D map view.
We are not able to use the animation function within the 3D map as our camera is static and we are changing the visibility preset between each frame to load in a different time step.
Are any of the 3D map view capabilities exposed and useable from the QGIS python console? From some Google searches I could not find any discussion or documentation on the topic.
Our preferred workflow would be to be able to use the 3D map within an atlas so that we can add text and other items to the view (we are post processing the images to add this), however it does not appear that 3D views can be used with data defined overrides at this time.
Any direction you can provide would be appreciated as it is quite a manual process to export a reasonable number of frames to stitch together into a video.
Regards,
Ryan
*** Advisian Notice *** "This email is confidential. If you are not the intended recipient, you must not disclose or use the information contained in it. If you have received this email in error, please notify us immediately by return email and delete the email and any attachments. Any personal views or opinions expressed by the writer may not necessarily reflect the views or opinions of any company in the WorleyParsons Group of Companies. How we use your personal data: http://www.advisian.com/en-us/who-we-are/privacy-policy /SPAN>
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.osgeo.org_mailman_listinfo_qgis-2Duser&d=DwMGaQ&c=Qznq1V5e4u04CfMRj920aPtDqN4RUEToMeZ6oK6t9iY&r=uiqzTG8TwLDffFCXwMoj3xc-xooTKMeCCK7zRJUQhc4&m=7oIhQMHLN-WS9xKnb0W7-5PT9nfqx-sECvi6bvCvM7c&s=Z6lG3OYCW2YjxaRMSBqyFDUFe3bzJJEsv_S5UJQ0Ou0&e=>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.osgeo.org_mailman_listinfo_qgis-2Duser&d=DwMGaQ&c=Qznq1V5e4u04CfMRj920aPtDqN4RUEToMeZ6oK6t9iY&r=uiqzTG8TwLDffFCXwMoj3xc-xooTKMeCCK7zRJUQhc4&m=7oIhQMHLN-WS9xKnb0W7-5PT9nfqx-sECvi6bvCvM7c&s=Z6lG3OYCW2YjxaRMSBqyFDUFe3bzJJEsv_S5UJQ0Ou0&e=>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190701/fd066077/attachment.html>
