[Qgis-user] Extend feature not working in 3.6.0?
Loïc Bartoletti
lbartoletti at tuxfamily.org
Sun Mar 3 22:36:27 PST 2019
It's the same way. Select the limit and then select the part to be
trimmed. You can see a demonstration on multiline geometry in this video
https://raw.githubusercontent.com/lbartoletti/lbartoletti.github.io/master/trim_extend.webm
Regards.
Loïc
Le 28/02/2019 à 08:42, Luca Manganelli a écrit :
> I have explained badly. The documentation explains the EXTEND command
> cleary; that I don't understand is how to TRIM. :-)
> Il giorno gio 28 feb 2019 alle ore 08:14 DelazJ <delazj at gmail.com
> <mailto:delazj at gmail.com>> ha scritto:
> Hi,
> Le jeu. 28 févr. 2019 à 08:11, Luca Manganelli
> <luca.manganelli at comune.trento.it
> <mailto:luca.manganelli at comune.trento.it>> a écrit :
> Thank you. I understood how to EXTEND (but the documentation
> wasn't explain too well),
> Luca, would you mind proposing a fix for what you missed in the
> proposed documentation?
> Thanks,
> Harrissou
> but not how to TRIM... :-)
> Il giorno gio 28 feb 2019 alle ore 07:42 Loïc Bartoletti
> <lbartoletti at tuxfamily.org <mailto:lbartoletti at tuxfamily.org>>
> ha scritto:
> Hi Luca,
> You must activate segment snapping for this tool to work.
> The documentation is ready but not available online. You
> can see the two PR for this documentation:
> https://github.com/qgis/QGIS-Documentation/pull/3171/files
> https://github.com/qgis/QGIS-Documentation/pull/3343/files
> Regards
> Loïc
> Le 28/02/2019 à 07:33, Luca Manganelli a écrit :
>> I've tried the new extend tool. I've followed these steps:
>> 1. Create a new temporary multiline string layer;
>> 2. Created two new lines;
>> 3. Clicked on Extend/Trim tool;
>> 4. I've moved over feature, clicked on it, it seems that
>> is not working
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:
> Luca Manganelli
> Assistente informatico
> Servizio Innovazione e Sistemi digitali
> Via Ezio Maccani 148
> 38121 Trento (TN)
> Luca Manganelli
> 38121 Trento (TN)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190304/da579a67/attachment.html>
