[Qgis-user] QGIS 3 Frozen
Martin Bittens martin.bittens at gmx.de
Wed Mar 6 04:15:30 PST 2019
Hello Colleagues,
here an update about problems with the plugin manager (as described in
my previous email):
By incidence I discovered that my internet connection via the wifi
router changed from 2.4GHz to 5GHz. That means I did the download and
installation of the QGIS updates using the 5GHz connection (without any
problems). Starting QGIS and trying to open the plugin manger led to a
frozen QGIS, as already mentioned. Just because I didn't get any idea
how to solve the problem I switched the internet connection back to
2.4GHZ (remembering that in the past I always used this connection and
didn't get any problems with the plugin manager).
The result: In QGIS 3.7.0 and 3.6.0 the plugin manager is working, in
QGIS 3.4.5 I got this:
The 'Copy Report' button is greyed out, creation of a report does not work.
Can anybody give an explanation what is going on with QGIS?
I do not understand:
1.) why the use of the plugin manager is depending on the type of the
internet connection (2.4GHz/5GHz) and
2.) why QGIS 3.4.5 is crashing anyway independent if I am using a 2.4GHz
or a 5GHz connection?
Thank you for your help.
Martin
Am 3/5/2019 um 12:24 PM schrieb Martin Bittens:
> Hello Colleagues,
> After I made the latest update I don“t get access to the plugin
> manager. Clicking on 'Plugins - Manage and Install Plugins...' QGIS
> stops to work. No error message appears, and to close QGIS I need to
> use the windows task manager. Currently, there are 3 QGIS versions on
> my computer:
> QGIS 3.4.5
> QGIS 3.6.0
> QGIS 3.7.0
> The result is always the same. QGIS is frozen.
> I am working with Windows 10.
> Does anybody know what is the reason for that error?
> Thank your for your help.
> Martin
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190306/5e4d7eaa/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190306/5e4d7eaa/attachment-0001.jpg>
