[Qgis-user] Error saving/exporting data with many attributes
Patrick Dunford enzedrailmaps at gmail.com
Tue Mar 12 03:44:57 PDT 2019
Case sensitive names (from experience) are handled inconsistently within
the Qgis software. It would be unwise to have two different columns
where the names are only distinguished by case, unless the developers
choose to address these issues in future.
On 12/03/19 12:20 AM, b.j.kobben at utwente.nl wrote:
> To answer my own question: the problem is actually not the amount of
> attributes, but the fact that there are (2x) attributes columns with
> the same name (although they are different if you consider case
> sensitivity). Apparently GeoJSON is the only format that allows
> differentiating column names by upper/lowercase....
> yours,
> Barend Köbben
> On 11/03/2019, 11:55, "Qgis-user on behalf of b.j.kobben at utwente.nl
> <mailto:b.j.kobben at utwente.nl>" <qgis-user-bounces at lists.osgeo.org
> <mailto:qgis-user-bounces at lists.osgeo.org> on behalf of
> b.j.kobben at utwente.nl <mailto:b.j.kobben at utwente.nl>> wrote:
> Hi all,
> I have a problem that (I think) comes down to a limit in the amount of
> attributes per object the QGIS exporting tools can handle.  Case in hand:
> 1) Import OSM data Points with many attributes (OSM tags), using
> QuickOSM – works
> 2) Temporary layer in QGIS is displayed -  seems fine
> 3) "Make Permanent" or "Export As..." fails on all file formats
> (_except_ GeoJSON!). Error message is (for the GeoPackage case):
> Export to vector file failed.
> Error: Feature write errors:
> Feature creation error (OGR error: sqlite3_exec(CREATE TABLE "test" (
> "fid" INTEGER PRIMARY KEY AUTOINCREMENT NOT NULL, "geom" POINT,
> "full_id" TEXT(255), "osm_id" TEXT(255), "osm_type" TEXT(255),
> "highway" TEXT(255),
> ... many more attributes...
> "safe_place:school" TEXT(255), "safe_place:mosque" TEXT(255))) failed:
> duplicate column name: Operational_status)
> Feature creation error (OGR error: failed to prepare SQL: INSERT INTO
> "test" ( "geom", "full_id", "osm_id", "osm_type", "highway", "name",
> ... again the same many more attributes...
> "safe_place:school", "safe_place:mosque") VALUES (?, ?, ?, ?, ?, ?, ?,
> This happens even when I have only 2 features (see attached test
> file). The workaraound is to use GeoJSON, bacuse for some reason that
> one works, but in normal case I have 1000s of points instead of two,
> and then a GeoJSON file becomes very large and unwieldy...
> Any ideas if this is a bug or a limit in the actual formats such as
> GeoPackage...?
> yours,
> Barend Köbben
> Senior Lecturer – ITC-University of Twente & ATLAS
> PO Box 217, 7500 AE Enschede (Netherlands)
> ITC Building (room 1-065)
> @barendkobben
> +31-(0)53 4874 253
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190312/232b8ef8/attachment.html>
