[Qgis-user] Error saving/exporting data with many attributes
    b.j.kobben at utwente.nl
    Tue Mar 12 08:35:49 PDT 2019
Thanks for the info Patrick. I totally agree this is unwise, but the OSM (OpenStreetMap) dataset I am working with unfortunately comes with some of these (unwisely chosen) attribute tags :-(
So indeed inconsistency in how that 's handled is annoying. In defence of QGIS programmers, I think it's because the different import/export formats have different rules and defaults...
yours,
Barend Köbben
On 12/03/2019, 11:45, "Qgis-user on behalf of Patrick Dunford" <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org> on behalf of enzedrailmaps at gmail.com<mailto:enzedrailmaps at gmail.com>> wrote:
Case sensitive names (from experience) are handled inconsistently within the Qgis software. It would be unwise to have two different columns where the names are only distinguished by case, unless the developers choose to address these issues in future.
On 12/03/19 12:20 AM, b.j.kobben at utwente.nl<mailto:b.j.kobben at utwente.nl> wrote:
To answer my own question: the problem is actually not the amount of attributes, but the fact that there are (2x) attributes columns with the same name (although they are different if you consider case sensitivity). Apparently GeoJSON is the only format that allows differentiating column names by upper/lowercase....
yours,
Barend Köbben
On 11/03/2019, 11:55, "Qgis-user on behalf of b.j.kobben at utwente.nl<mailto:b.j.kobben at utwente.nl>" <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org> on behalf of b.j.kobben at utwente.nl<mailto:b.j.kobben at utwente.nl>> wrote:
Hi all,
I have a problem that (I think) comes down to a limit in the amount of attributes per object the QGIS exporting tools can handle.  Case in hand:
1) Import OSM data Points with many attributes (OSM tags), using QuickOSM – works
2) Temporary layer in QGIS is displayed -  seems fine
3) "Make Permanent" or "Export As..." fails on all file formats (except GeoJSON!). Error message is (for the GeoPackage case):
Export to vector file failed.
Error: Feature write errors:
Feature creation error (OGR error: sqlite3_exec(CREATE TABLE "test" ( "fid" INTEGER PRIMARY KEY AUTOINCREMENT NOT NULL, "geom" POINT, "full_id" TEXT(255), "osm_id" TEXT(255), "osm_type" TEXT(255), "highway" TEXT(255),
... many more attributes...
"safe_place:school" TEXT(255), "safe_place:mosque" TEXT(255))) failed: duplicate column name: Operational_status)
Feature creation error (OGR error: failed to prepare SQL: INSERT INTO "test" ( "geom", "full_id", "osm_id", "osm_type", "highway", "name",
... again the same many more attributes...
"safe_place:school", "safe_place:mosque") VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?))
This happens even when I have only 2 features (see attached test file). The workaraound is to use GeoJSON, bacuse for some reason that one works, but in normal case I have 1000s of points instead of two, and then a GeoJSON file becomes very large and unwieldy...
Any ideas if this is a bug or a limit in the actual formats such as GeoPackage...?
yours,
Barend Köbben
Senior Lecturer – ITC-University of Twente & ATLAS
PO Box 217, 7500 AE Enschede (Netherlands)
ITC Building (room 1-065)
@barendkobben
+31-(0)53 4874 253
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190312/0851b04e/attachment.html>
