[Qgis-user] qgis-providers error
Patrick Dunford
enzedrailmaps at gmail.com
Sun Mar 17 19:36:23 PDT 2019
Please provide the list of repositories which you are using to install Qgis
On 17/03/19 8:26 PM, Diogo Amore wrote:
> Dear admin,
> I am currently experiencing an issue I have never had with QGIS in
> Ubuntu 18.04. I used it for months without any issues but suddenly,
> this week, Qgis would not start and as I attempted to remove and
> reinstall it from scratch I got the following error:
> /Setting up qgis-providers (1:3.6.0+28bionic) .../
> /Cannot mix incompatible Qt library (version 0x50905) with this
> library (version 0x50b01)/
> /Aborted/
> /dpkg: error processing package qgis-providers (--configure):/
> / installed qgis-providers package post-installation script subprocess
> returned error exit status 134/
> /dpkg: dependency problems prevent configuration of qgis:/
> / qgis depends on qgis-providers (= 1:3.6.0+28bionic); however:/
> / Package qgis-providers is not configured yet./
> /dpkg: error processing package qgis (--configure):/
> / dependency problems - leaving unconfigured/
> /dpkg: dependency problems prevent configuration of qgis-plugin-grass:/
> / qgis-plugin-grass depends on qgis (= 1:3.6.0+28bionic); however:/
> / Package qgis is not configured yet./
> /dpkg: error processing package qgis-plugin-grass (--configure):/
> /No apport report written because the error message indicates it's a
> follow-up error from a previous failure./
> / No apport report written because the error message
> indicates it's a follow-up error from a previous failure./
> / Errors were encountered while processing:/
> / qgis-providers/
> / qgis/
> / qgis-plugin-grass/
> /E: Sub-process /usr/bin/dpkg returned an error code (1)/
> /Aborted/
> /Errors were encountered while processing:/
> / qgis-providers/
> / qgis/
> I have never had any such issue due to Qt libraries. Also, I have not
> updated nor changed anything from Qt versions installed. QGis simply
> started showing this issue, and with the release of QGis 3.6 I assumed
> there could be something to do with it, but I am not sure what exactly.
> Any ideas on why this is so?
> Thanks
> Diogo
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190318/b57eb9b8/attachment.html>
