[Qgis-user] Filegeodatabase editing
Tyler Veinot
tylerkveinot at gmail.com
Mon Mar 18 08:18:36 PDT 2019
Thank you for the reply but I think you might be refering to a Personal
Geodatabase, those need an ODBC driver and cannot be edited in QGIS. A
Filegeodatabase on the other hand can be edited directly in 2.18.x using
the OGR Filegeodatabase driver that can be installed using the advanced
options in the OGR installer; the issue of not being able to edit is
recent. Last week I could edit, this week I cannot.
I did a clean install of the QGIS3 application using the OSGeo Installer
and the editor is working using the OGR filegeodatabase drive but when I
select save edits I get " OGR error creating feature -2: Failed at writing
Row to Table in CreateFeature. (The user does not have permission to
execute the operation.)"
I noticed all my file geodatabases are showing a "read only" attribute that
will not go away. I can still edit them in ArcMap but nothing else. I
checked for *.lock files and removed them as well. Tyler
On Mon, Mar 18, 2019 at 11:52 AM Antongeo76 <antoviscomi at gmail.com> wrote:
> Tyler Veinot-2 wrote
> > Hi All;
> > Has anyone had issues editing filegeodatabases in QGIS?
> > In 2.18X I was editing file geodatabase data painlessly but since QGIS
> LTR
> > went to 3.4.x and switched over I get an error on saving (you do not have
> > permissions to edit this data). I tried running QGIS as administrator and
> > I
> > tried reinstalling 2.18.x but now 2.18.x will not even give me the option
> > to start editing, the pencil is greyed out.
> > I uninstalled the filegeodatabase drive and installed the
> > filegeodatabase-dev drive and now the oencil icon is greyed out in 3.4.x
> > and 3.6.x.
> > Has this happened to anyone else before? How did you resolve it?
> > Tyler
> > Qgis-user mailing list
> > Qgis-user at .osgeo
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> HI tyler,
> Yes I use currently .gdb in QGIS but the ODBC drivers are read only then I
> don't be able to directly editing .gdb I save te feature I need to edit in
> .shp then I can edit It
> Regards
> Antonio
> Antonio
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190318/42071c64/attachment.html>
