[Qgis-user] Filegeodatabase editing
Antongeo76
antoviscomi at gmail.com
Mon Mar 18 08:45:17 PDT 2019
Tyler Veinot-2 wrote
> Thank you for the reply but I think you might be refering to a Personal
> Geodatabase, those need an ODBC driver and cannot be edited in QGIS. A
> Filegeodatabase on the other hand can be edited directly in 2.18.x using
> the OGR Filegeodatabase driver that can be installed using the advanced
> options in the OGR installer; the issue of not being able to edit is
> recent. Last week I could edit, this week I cannot.
> I did a clean install of the QGIS3 application using the OSGeo Installer
> and the editor is working using the OGR filegeodatabase drive but when I
> select save edits I get " OGR error creating feature -2: Failed at writing
> Row to Table in CreateFeature. (The user does not have permission to
> execute the operation.)"
> I noticed all my file geodatabases are showing a "read only" attribute
> that
> will not go away. I can still edit them in ArcMap but nothing else. I
> checked for *.lock files and removed them as well. Tyler
> On Mon, Mar 18, 2019 at 11:52 AM Antongeo76 <
> antoviscomi@
>> > Hi All;
>> > Has anyone had issues editing filegeodatabases in QGIS?
>> > In 2.18X I was editing file geodatabase data painlessly but since QGIS
>> LTR
>> > went to 3.4.x and switched over I get an error on saving (you do not
>> have
>> > permissions to edit this data). I tried running QGIS as administrator
>> and
>> > I
>> > tried reinstalling 2.18.x but now 2.18.x will not even give me the
>> option
>> > to start editing, the pencil is greyed out.
>> > I uninstalled the filegeodatabase drive and installed the
>> > filegeodatabase-dev drive and now the oencil icon is greyed out in
>> 3.4.x
>> > and 3.6.x.
>> > Has this happened to anyone else before? How did you resolve it?
>> > Tyler
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at .osgeo
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> HI tyler,
>> Yes I use currently .gdb in QGIS but the ODBC drivers are read only then
>> I
>> don't be able to directly editing .gdb I save te feature I need to edit
>> in
>> .shp then I can edit It
>> Regards
>> Antonio
>> Antonio
>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user at .osgeo
> Qgis-user at .osgeo
Ok Tyler,
sorry for misunderstanding.
I'm able to edit .gdb with no troubles on QGIS 2.18.28 updated just now GDAL
FileGDB VERSSION ARE 2.5.0.87 (dev)
2.4.0-7 (stable)
I'm working in on windows 7 ultimate
Versione di QGIS
2.18.28
Revisione codice QGIS
aa30730ac6
Compilato con Qt
4.8.5
Esecuzione con Qt
4.8.5
Compilato con GDAL/OGR
2.4.0
Esecuzione con GDAL/OGR
2.4.0
Compilato con GEOS
3.7.0-CAPI-1.11.0
Esecuzione con GEOS
3.7.0-CAPI-1.11.0 673b9939
Versione client PostgreSQL
9.2.4
Versione SpatiaLite
4.3.0
Versione QWT
5.2.3
Versione PROJ.4
520
Versione QScintilla2
2.7.2
Hope this can help you
cheers
Antonio
