[Qgis-user] Filegeodatabase editing
Tyler Veinot tylerkveinot at gmail.com
Mon Mar 18 11:24:11 PDT 2019
So far I discovreed it either has something to do with the qgz file or
permissions on the server. I can edit the file geodatabase when it is on my
localdisk, I can edit it when it is on the network drive when I just open a
new qgz file add a featureclass and edit, but when I use my working qgz map
document it keeps saying I don't have permissions. It was working but now
it is doing it again not sure what is up. I have the read only unchecked in
the map doc too...
Tyler
On Mon, Mar 18, 2019 at 2:55 PM Rick Rupp <palousegeo at outlook.com> wrote:
> Hi Tyler,
> I can create, edit and save to fileGDB with QGIS 3.6.0 (OSGEO4W).
> -Rick
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of Tyler
> Veinot <tylerkveinot at gmail.com>
> *Sent:* Monday, March 18, 2019 8:18:36 AM
> *To:* Antongeo76
> *Cc:* QGIS User List
> *Subject:* Re: [Qgis-user] Filegeodatabase editing
> Thank you for the reply but I think you might be refering to a Personal
> Geodatabase, those need an ODBC driver and cannot be edited in QGIS. A
> Filegeodatabase on the other hand can be edited directly in 2.18.x using
> the OGR Filegeodatabase driver that can be installed using the advanced
> options in the OGR installer; the issue of not being able to edit is
> recent. Last week I could edit, this week I cannot.
> I did a clean install of the QGIS3 application using the OSGeo Installer
> and the editor is working using the OGR filegeodatabase drive but when I
> select save edits I get " OGR error creating feature -2: Failed at
> writing Row to Table in CreateFeature. (The user does not have permission
> to execute the operation.)"
> I noticed all my file geodatabases are showing a "read only" attribute
> that will not go away. I can still edit them in ArcMap but nothing else. I
> checked for *.lock files and removed them as well. Tyler
> On Mon, Mar 18, 2019 at 11:52 AM Antongeo76 <antoviscomi at gmail.com> wrote:
>> Tyler Veinot-2 wrote
>> > Hi All;
>> > Has anyone had issues editing filegeodatabases in QGIS?
>> > In 2.18X I was editing file geodatabase data painlessly but since QGIS
>> LTR
>> > went to 3.4.x and switched over I get an error on saving (you do not
>> have
>> > permissions to edit this data). I tried running QGIS as administrator
>> and
>> > I
>> > tried reinstalling 2.18.x but now 2.18.x will not even give me the
>> option
>> > to start editing, the pencil is greyed out.
>> > I uninstalled the filegeodatabase drive and installed the
>> > filegeodatabase-dev drive and now the oencil icon is greyed out in 3.4.x
>> > and 3.6.x.
>> > Has this happened to anyone else before? How did you resolve it?
>> > Tyler
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at .osgeo
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> HI tyler,
>> Yes I use currently .gdb in QGIS but the ODBC drivers are read only then I
>> don't be able to directly editing .gdb  I save te feature I need to edit
>> in
>> .shp then I can edit It
>> Regards
>> Antonio
>> Antonio
>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190318/caa194c2/attachment.html>
