[Qgis-user] Filegeodatabase editing
    Tyler Veinot
    tylerkveinot at gmail.com
    Mon Mar 18 11:35:21 PDT 2019
Correction, I can edit the layers I have not recently edited with ArcMap,
anything I edited with ArcMap last week I cannot edit in QGIS now.
I checked and the .lock files are all gone and ArcMap is completely shut
downs so not sure what is locking the layers.
Tyler
On Mon, Mar 18, 2019 at 3:24 PM Tyler Veinot <tylerkveinot at gmail.com> wrote:
> So far I discovreed it either has something to do with the qgz file or
> permissions on the server. I can edit the file geodatabase when it is on my
> localdisk, I can edit it when it is on the network drive when I just open a
> new qgz file add a featureclass and edit, but when I use my working qgz map
> document it keeps saying I don't have permissions. It was working but now
> it is doing it again not sure what is up. I have the read only unchecked in
> the map doc too...
> Tyler
> On Mon, Mar 18, 2019 at 2:55 PM Rick Rupp <palousegeo at outlook.com> wrote:
>> Hi Tyler,
>> I can create, edit and save to fileGDB with QGIS 3.6.0 (OSGEO4W).
>> -Rick
>> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of Tyler
>> *Sent:* Monday, March 18, 2019 8:18:36 AM
>> *To:* Antongeo76
>> *Cc:* QGIS User List
>> *Subject:* Re: [Qgis-user] Filegeodatabase editing
>> Thank you for the reply but I think you might be refering to a Personal
>> Geodatabase, those need an ODBC driver and cannot be edited in QGIS. A
>> Filegeodatabase on the other hand can be edited directly in 2.18.x using
>> the OGR Filegeodatabase driver that can be installed using the advanced
>> options in the OGR installer; the issue of not being able to edit is
>> recent. Last week I could edit, this week I cannot.
>> I did a clean install of the QGIS3 application using the OSGeo Installer
>> and the editor is working using the OGR filegeodatabase drive but when I
>> select save edits I get " OGR error creating feature -2: Failed at
>> writing Row to Table in CreateFeature. (The user does not have permission
>> to execute the operation.)"
>> I noticed all my file geodatabases are showing a "read only" attribute
>> that will not go away. I can still edit them in ArcMap but nothing else. I
>> checked for *.lock files and removed them as well. Tyler
>> On Mon, Mar 18, 2019 at 11:52 AM Antongeo76 <antoviscomi at gmail.com>
>> wrote:
>>> Tyler Veinot-2 wrote
>>> > Hi All;
>>> > Has anyone had issues editing filegeodatabases in QGIS?
>>> > In 2.18X I was editing file geodatabase data painlessly but since QGIS
>>> LTR
>>> > went to 3.4.x and switched over I get an error on saving (you do not
>>> have
>>> > permissions to edit this data). I tried running QGIS as administrator
>>> and
>>> > I
>>> > tried reinstalling 2.18.x but now 2.18.x will not even give me the
>>> option
>>> > to start editing, the pencil is greyed out.
>>> > I uninstalled the filegeodatabase drive and installed the
>>> > filegeodatabase-dev drive and now the oencil icon is greyed out in
>>> 3.4.x
>>> > and 3.6.x.
>>> > Has this happened to anyone else before? How did you resolve it?
>>> > Tyler
>>> > _______________________________________________
>>> > Qgis-user mailing list
>>> > Qgis-user at .osgeo
>>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> HI tyler,
>>> Yes I use currently .gdb in QGIS but the ODBC drivers are read only then
>>> I
>>> don't be able to directly editing .gdb  I save te feature I need to edit
>>> in
>>> .shp then I can edit It
>>> Regards
>>> Antonio
>>> Antonio
>>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>>> Qgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190318/75c53ccb/attachment.html>
