[Qgis-user] Filegeodatabase editing
Alex M
tech_dev at wildintellect.com
Tue Mar 19 09:14:47 PDT 2019
Did you recently upgrade ArcMap? I'm wondering if your gdb changed
internal versions?
Thanks,
Alex
On 3/18/19 11:35, Tyler Veinot wrote:
> Correction, I can edit the layers I have not recently edited with ArcMap,
> anything I edited with ArcMap last week I cannot edit in QGIS now.
> I checked and the .lock files are all gone and ArcMap is completely shut
> downs so not sure what is locking the layers.
> Tyler
> On Mon, Mar 18, 2019 at 3:24 PM Tyler Veinot <tylerkveinot at gmail.com> wrote:
>> So far I discovreed it either has something to do with the qgz file or
>> permissions on the server. I can edit the file geodatabase when it is on my
>> localdisk, I can edit it when it is on the network drive when I just open a
>> new qgz file add a featureclass and edit, but when I use my working qgz map
>> document it keeps saying I don't have permissions. It was working but now
>> it is doing it again not sure what is up. I have the read only unchecked in
>> the map doc too...
>> Tyler
>> On Mon, Mar 18, 2019 at 2:55 PM Rick Rupp <palousegeo at outlook.com> wrote:
>>> Hi Tyler,
>>> I can create, edit and save to fileGDB with QGIS 3.6.0 (OSGEO4W).
>>> -Rick
>>> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of Tyler
>>> *Sent:* Monday, March 18, 2019 8:18:36 AM
>>> *To:* Antongeo76
>>> *Cc:* QGIS User List
>>> *Subject:* Re: [Qgis-user] Filegeodatabase editing
>>> Thank you for the reply but I think you might be refering to a Personal
>>> Geodatabase, those need an ODBC driver and cannot be edited in QGIS. A
>>> Filegeodatabase on the other hand can be edited directly in 2.18.x using
>>> the OGR Filegeodatabase driver that can be installed using the advanced
>>> options in the OGR installer; the issue of not being able to edit is
>>> recent. Last week I could edit, this week I cannot.
>>> I did a clean install of the QGIS3 application using the OSGeo Installer
>>> and the editor is working using the OGR filegeodatabase drive but when I
>>> select save edits I get " OGR error creating feature -2: Failed at
>>> writing Row to Table in CreateFeature. (The user does not have permission
>>> to execute the operation.)"
>>> I noticed all my file geodatabases are showing a "read only" attribute
>>> that will not go away. I can still edit them in ArcMap but nothing else. I
>>> checked for *.lock files and removed them as well. Tyler
>>> On Mon, Mar 18, 2019 at 11:52 AM Antongeo76 <antoviscomi at gmail.com>
>>> wrote:
>>>> Tyler Veinot-2 wrote
>>>>> Hi All;
>>>>> Has anyone had issues editing filegeodatabases in QGIS?
>>>>> In 2.18X I was editing file geodatabase data painlessly but since QGIS
>>>> LTR
>>>>> went to 3.4.x and switched over I get an error on saving (you do not
>>>> have
>>>>> permissions to edit this data). I tried running QGIS as administrator
>>>> and
>>>>> I
>>>>> tried reinstalling 2.18.x but now 2.18.x will not even give me the
>>>> option
>>>>> to start editing, the pencil is greyed out.
>>>>> I uninstalled the filegeodatabase drive and installed the
>>>>> filegeodatabase-dev drive and now the oencil icon is greyed out in
>>>> 3.4.x
>>>>> and 3.6.x.
>>>>> Has this happened to anyone else before? How did you resolve it?
>>>>> Tyler
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at .osgeo
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> HI tyler,
>>>> Yes I use currently .gdb in QGIS but the ODBC drivers are read only then
>>>> I
>>>> don't be able to directly editing .gdb I save te feature I need to edit
>>>> in
>>>> .shp then I can edit It
>>>> Regards
>>>> Antonio
>>>> Antonio
>>>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>>>> Qgis-user at lists.osgeo.org
