[Qgis-user] Filegeodatabase editing
    Tyler Veinot
    tylerkveinot at gmail.com
    Tue Mar 19 09:00:59 PDT 2019
Ended up having to export all the layers I couldn't edit to shapefiles,
delete those layers in the fiel geodatabase using Arc Catalog, and import
the exported shapfiles to their respected locations in the file geodatabase
to get it to work again.
Not sure what happened but if anyone else runs into this that is what I had
to do.
Cheers
On Tue, Mar 19, 2019 at 8:43 AM Tyler Veinot <tylerkveinot at gmail.com> wrote:
> Spoke too soon, it seems to be only specific layers in the geodatabase,
> layers recently edited by Arc. I tried copying the database to my local the
> issue seems to come with it.
> Tyler
> On Mon, Mar 18, 2019 at 1:31 PM Tyler Veinot <tylerkveinot at gmail.com>
> wrote:
>> I deleted the QGIS folders from my profile and reinstalled. My H: drive
>> is back, the one that was missing, now the P, G, and K, are gone. So using
>> the favorites I added the missing drives to favorites and they appeared in
>> the drive list below. Then I removed them from favorities. Re-opened the
>> file geodatabase and now can edit and save those edits.
>> I don't know what went ary on me but it seems to be ok now...
>> Thanks for the help, I didn't get a chance to copy the geodatabase to my
>> local though.
>> TYler
>> On Mon, Mar 18, 2019 at 1:03 PM DT <dmofot at gmail.com> wrote:
>>> Ah, yea, I've seen issues with files on network drives before.  If
>>> possible, you might copy it locally just to see if that works.
>>> On Mon, Mar 18, 2019 at 12:01 PM Tyler Veinot <tylerkveinot at gmail.com>
>>> wrote:
>>>> I am using the fielgeodatabase drive not the open geodatabase drive. I
>>>> created a new filegeodatabase with a points dataset and was able to edit it
>>>> fine with no issues. My network drive containing the file geodatabase I am
>>>> having issues with has disappeared from the qgis browser and is not an
>>>> option in the add data panel. Yet it is there in my file explorer. I think
>>>> the issue has something to do with the network or an install issue not sure
>>>> now...
>>>> Tyler
>>>> On Mon, Mar 18, 2019 at 12:48 PM DT <dmofot at gmail.com> wrote:
>>>>> Tyler, which geodatabase driver are you using - openfilegdb [1] or
>>>>> filegdb [2] [3]?  You could start with a "ogrinfo --formats" to see whether
>>>>> using the openfilegdb or filegdb.  If using filegdb, you can try using GDAL
>>>>> via the command line to see if you can edit the geodatabase.
>>>>> [1] https://www.gdal.org/drv_openfilegdb.html
>>>>> [2] https://www.gdal.org/drv_filegdb.html
>>>>> [3] https://github.com/Esri/file-geodatabase-api/
>>>>> On Mon, Mar 18, 2019 at 11:18 AM Tyler Veinot <tylerkveinot at gmail.com>
>>>>> wrote:
>>>>>> Thank you for the reply but I think you might be refering to a
>>>>>> Personal Geodatabase, those need an ODBC driver and cannot be edited in
>>>>>> QGIS. A Filegeodatabase on the other hand can be edited directly in 2.18.x
>>>>>> using the OGR Filegeodatabase driver that can be installed using the
>>>>>> advanced options in the OGR installer; the issue of not being able to edit
>>>>>> is recent. Last week I could edit, this week I cannot.
>>>>>> I did a clean install of the QGIS3 application using the OSGeo
>>>>>> Installer and the editor is working using the OGR filegeodatabase drive but
>>>>>> when I select save edits I get " OGR error creating feature -2:
>>>>>> Failed at writing Row to Table in CreateFeature. (The user does not have
>>>>>> permission to execute the operation.)"
>>>>>> I noticed all my file geodatabases are showing a "read only"
>>>>>> attribute that will not go away. I can still edit them in ArcMap but
>>>>>> nothing else. I checked for *.lock files and removed them as well. Tyler
>>>>>> On Mon, Mar 18, 2019 at 11:52 AM Antongeo76 <antoviscomi at gmail.com>
>>>>>> wrote:
>>>>>>> Tyler Veinot-2 wrote
>>>>>>> > Hi All;
>>>>>>> > Has anyone had issues editing filegeodatabases in QGIS?
>>>>>>> > In 2.18X I was editing file geodatabase data painlessly but since
>>>>>>> QGIS LTR
>>>>>>> > went to 3.4.x and switched over I get an error on saving (you do
>>>>>>> not have
>>>>>>> > permissions to edit this data). I tried running QGIS as
>>>>>>> administrator and
>>>>>>> > I
>>>>>>> > tried reinstalling 2.18.x but now 2.18.x will not even give me the
>>>>>>> option
>>>>>>> > to start editing, the pencil is greyed out.
>>>>>>> > I uninstalled the filegeodatabase drive and installed the
>>>>>>> > filegeodatabase-dev drive and now the oencil icon is greyed out in
>>>>>>> 3.4.x
>>>>>>> > and 3.6.x.
>>>>>>> > Has this happened to anyone else before? How did you resolve it?
>>>>>>> > Tyler
>>>>>>> > _______________________________________________
>>>>>>> > Qgis-user mailing list
>>>>>>> > Qgis-user at .osgeo
>>>>>>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>> HI tyler,
>>>>>>> Yes I use currently .gdb in QGIS but the ODBC drivers are read only
>>>>>>> then I
>>>>>>> don't be able to directly editing .gdb  I save te feature I need to
>>>>>>> edit in
>>>>>>> .shp then I can edit It
>>>>>>> Regards
>>>>>>> Antonio
>>>>>>> Antonio
>>>>>>> Sent from:
>>>>>>> http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>>>>>>> Qgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190319/0977f837/attachment.html>
