[Qgis-user] QGIS and remote PostgreSQL/PostGIS slow performance
Eduardo Rojas Rodríguez
eduardo.rojas at soltig.net
Tue Mar 19 10:28:15 PDT 2019
Hi List!!
I am looking for help with the following topic, I appreciate any guide or
comment
I'm using a cloud service for hosting my PostgreSQL/PostGIS database.
When connecting with QGIS, its extremely slow.
The observed behavior is:
Connecting to PostGIS DB: works great.
Adding a layer to the map view: A bit slow but noting to worry
Open attribute table: really really slow, up to 45 seconds to open a *small
table of 100 point* (QGIS become freeze and won't respond until the table
open)
When Editing a layer in the PostGIS
Adding a new feature or editing the values of the attribute table: 45
seconds to get the form for insert the attributes and when saving the edit
another 45sec. (sometimes can get worse if the geometry added its complex
with alot of nodes its can take up to 3 min)
So I'm investigate a little and make some test, maybe the latency between my
client QGIS (my PC) and the PostGis (cloud db) its the problem:
I'm using the Azure Database for PostgreSQL and the server is in US East
region, so I did the network test between client - host to see is the
latency is the problem:
Using psql:
\timing
SELECT;
\watch 1
I get the following values:
83 - 84ms so it's not that bad, noting to get 45 sec in QGIS and the results
are consistent with the ping from my location to the Azure server.
The DB performance looks ok since it's a really small db and queries with
pgadmin o psql are fast.
QGIS is in a “old” gaming laptop, no ssd and the internet it’s limited as
well. despite this I am not doing anything that in my opinion requires a
very high performance, QGIS works excellent and is fast in my PC or in a
local PostGIS. It’s when it’s go to the cloud when the slowness appears
Someone with experience using cloud db for using with QGIS maybe can guide
me or give me an insight, maybe I'm missing a QGIS configuration or host
server networking config.
Analista en SIG
Soluciones en Tecnologías
Tel: 506 2505-5453
http://soltig.net
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
