[Qgis-user] Coordinates from wgs84 utm /expressed in meter) to wgs84 (expressed in degrees)
Azzurra Lentini
lentini.azzurra at polymtl.ca
Tue Mar 19 10:43:52 PDT 2019
Good morning,
if for example my project is in this referencing system: WGS84-UTM,
when I ask to calculate the coordinates Y and X (with field calculator
- geometry), it will produce the coordinates in meters.
But what can I do if I want the same coordinates in degrees?
(obviously in the same datum wgs84)
Thank you, Azzurra
An embedded message was scrubbed...
From: Azzurra Lentini <lentini.azzurra at polymtl.ca>
Subject: coordinates from wgs84 utm /expressed in meter) to wgs84 (expressed in degrees)
Date: Tue, 19 Mar 2019 17:26:32 +0000
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190319/4cdc6c4e/attachment.mht>
