[Qgis-user] Coordinates from wgs84 utm /expressed in meter) to wgs84 (expressed in degrees)
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Thu Mar 21 01:49:00 PDT 2019
Hi Nyall,
as much as I like your initiative to add such a function, I think such
examples should also be listed in the user manual connected to the field
calculator section.
Unfortunately, in this very important field, qgis resources do not give
many hints how to use the powers of the existing functions. Me, I do
100% of my searches on gis.stackexchange.com to find solution, not the docs.
Cheers,
Bernd
Am 21.03.19 um 08:05 schrieb Nyall Dawson:
> On Wed, 20 Mar 2019 at 03:55, Azzurra Lentini
> <lentini.azzurra at polymtl.ca> wrote:
>> Good morning,
>> if for example my project is in this referencing system: WGS84-UTM,
>> when I ask to calculate the coordinates Y and X (with field calculator
>> - geometry), it will produce the coordinates in meters.
>> But what can I do if I want the same coordinates in degrees?
>> (obviously in the same datum wgs84)
> I think this is a common enough task to warrant it's own processing
> algorithm. I've added one in https://github.com/qgis/QGIS/pull/9587
> (so will be in 3.8), ported from some Python code I used at a
> customer's workplace.
> Nyall
> Qgis-user mailing list
