[Qgis-user] Coordinates from wgs84 utm /expressed in meter) to wgs84 (expressed in degrees)
    DelazJ
    delazj at gmail.com
    Thu Mar 21 17:47:47 PDT 2019
Hi Bernd,
Le jeu. 21 mars 2019 à 09:49, Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
a écrit :
> Hi Nyall,
> as much as I like your initiative to add such a function, I think such
> examples should also be listed in the user manual connected to the field
> calculator section.
> Unfortunately, in this very important field, qgis resources do not give
> many hints how to use the powers of the existing functions. Me, I do
> 100% of my searches on gis.stackexchange.com to find solution, not the
> docs.
>  As you might certainly know, the doc IS a community-driven work and we
welcome any contribution. So if you feel something is worth mentioning and
you know how to fix it, please simply provide a text or a pull request[0]
and it'll get done.
 This is how things work. And if people have to do 100% of their searches
out of the docs, maybe should we stop (trying) to maintain it.
[0] https://github.com/qgis/QGIS-Documentation
Regards,
Harrissou
Cheers,
> Bernd
> Am 21.03.19 um 08:05 schrieb Nyall Dawson:
> > On Wed, 20 Mar 2019 at 03:55, Azzurra Lentini
> > <lentini.azzurra at polymtl.ca> wrote:
> >> Good morning,
> >> if for example my project is in this referencing system: WGS84-UTM,
> >> when I ask to calculate the coordinates Y and X (with field calculator
> >> - geometry), it will produce the coordinates in meters.
> >> But what can I do if I want the same coordinates in degrees?
> >> (obviously in the same datum wgs84)
> > I think this is a common enough task to warrant it's own processing
> > algorithm. I've added one in https://github.com/qgis/QGIS/pull/9587
> > (so will be in 3.8), ported from some Python code I used at a
> > customer's workplace.
> > Nyall
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190322/efb36dc3/attachment.html>
